P.O.I Question
  • Thread starter mathmann
The slope of the curve y = ax(cubed) + bx(squared) + c is -12 at its point of inflection (2,-11), find a,b,c.
f ' (x) = 3ax(squared) + 2bx
f " (x) = 3ax + 2b
-12 = 3a2(squared) + 2b(2)
-12 = 12a + 4b
b = -3a - 3
-12 = 3a(2)(sqrd) + 2(-3a -3)
a = -1
b = 0
-11 = ax(cubed) + bx(sqrd) + c
c = -3
Answers and Replies
That is correct.
Another way to do it, and probably the one "expected" from you, is to use the fact that at the point of inflection, f''(x)=0.
not exactly sure how to do that..
6ax + 2b = 0?
Yes, that's right. Therefore b = -6a. Solve for a.
so b = 6 not 0?
so b = 6 not 0?
No, no!!
b = -6a is one relation, and is b = -3a - 3 is another. Now solve for a. Sorry for the confusion.
ur solution in OP is wrong . Check out step 5.
which do you consider step 5?
-12 = 3a(2)(sqrd) + 2(-3a -3)(?)
a 2 is missing in (?)
ok so a = 0 now
Sorry, my bad. As Sourabh has pointed out, your solution in the first post is in fact incorrect. a is not 0. What you would get from "step 5" is 0=0. That is because you got the relation bet. a and b from that very equation.
As I said earlier, use b = -6a and b = -3a -3 to solve for a.
-12=3ax(sqrd)+2(-6a)x
a=-1
b=6
c=-27
a=-1
Check again.
Once you get values for a, b and c, you can check if they are right by putting x=2 in the original equation and looking at the value you end up with.
ok im confused now.. ive found new values fro a(1),b(6) and c(5) but x doesnt = 2 when i enter it into the original equation.
i think there's again a calculation mistake in #12.
-12 = 3a2(sqrd) + 2(-6a)2
-12 = -12a
a=1.
ok i got that one are the other two right? b=6 and c=5?
b = -6 (b = -6a, remember?)
no. b=-6a=-6
-11 = 1*2(cubed) - 6*2(sqrd) +c
a=1, b=-6, c =5
is this correct?
You should get 3 equations:
[tex]12a + 2b = 0[/tex] (from 2nd derivative)
[tex]12a + 4b = -12[/tex] (from 1st derivative)
[tex]8a + 4b + c = -11[/tex] (from original equation)
Just solve for a,b,c from that info... I think you have all the right ideas, just getting wrong values.
Related Threads on P.O.I Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
