I Pair production proximity
  1. Oct 11, 2016 #1
    Does anyone know how close a photon needs to be to a nucleus (an ion really, no shielding from electrons) for pp to occur? I assume it's a probability as a function of distance, any ideas/equations?
    Thanks
  3. Oct 11, 2016 #2
    mfb
    2017 Award
    Staff: Mentor
    Photons do not have a well-defined position.
    There is a cross-section that depends on the nucleus and the photon energy, but don't interpret that as classical area.
  4. Oct 12, 2016 #3
    Does a photon have a definable (and quantized) angular momentum of its translational angular momentum past a target?
  5. Oct 12, 2016 #4
    Did you say pp on a bare nucleus with a photon? Good luck getting a photon of >2 GeV energy!!! and for the second part, charge conjugation occurs when the photon ( I seriously suggest a high-energy proton for this) enters the coulomb field of a nucleus (or another proton). The probability of pp increases with increasing energy from the threshold energy level, the equation that governs this : σ(pair E)≈αZ2r(electron)2InEγ
  6. Oct 12, 2016 #5
    vanhees71
    2017 Award
    Photons are special since they are massless. There's a unique gauge invariant definition of total angular momentum only. The split into orbital and spin-angular momentum is arbitrary and gauge dependent and thus unphysical.
    There are different complete one-photon bases. One is the momentum-helicity basis. These states are the usual plane-wave states of circular-left (##\lambda=-1##) and circular-right (##\lambda=+1##) polarization. Of course you could choose for each momentum any other polarization basis like linear polarized states etc.
    Another one is in terms of the usual multipole expansion, which is a energy-total-angular-momentum eigenbasis.
    This is all pretty similar to the free classical electromagnetic waves, only that in the corresponding Fourier decomposition the coefficients be come annihilation and creation operators for the corresponding photon states, with help of which you can build the Fock states (states with definite photon number).
    As a massless particle of spin 1 a photon by definition has no position in the literal sense, because there's no position operator that has the usual Heisenberg commutation relations with momentum.
  7. Oct 12, 2016 #6
    Vanadium 50
    Staff Emeritus
    Education Advisor
    2017 Award
    This is not a problem.
    All these messages are focusing on the same thing - getting a well-defined photon position is problem, and it becomes a bigger problem when you impose innocuous-seeming additional conditions (like 'exactly one'). What is well-defined, however, is the intersection of the electron and positron trajectories. That might be a sensible proxy.
  8. Oct 12, 2016 #7
    mfb
    2017 Award
    Staff: Mentor
    I read "pp" as "pair production", not "proton antiproton", but it does not matter. Multi-GeV photons (and even a few photons with more than 1 TeV, see e.g. this recent ATLAS publication) are routinely produced at colliders like the LHC.
    What does "charge conjugation occurs" mean? Charge conjugation is a mathematical operation. When does "addition of two numbers" occur in collision processes?
    I would be surprised if that works for hadron production.
  9. Oct 13, 2016 #8
    Its okay :wink:, and yes the equation is for pair-production of electron which, if I remember distinctly ,I mentioned in the equation. And yes again I forgot to mention both the equations for Hadron pp and that charge conjugation operator changes the signs of all quantum charges (dammit). Nevertheless I will get better, I'm still in the process of healing.
    PS: That article is nice! Keep me posted on latest stuff like this!
  10. Oct 13, 2016 #9
    mfb
    2017 Award
    Staff: Mentor
  11. Oct 13, 2016 #10
    ChrisVer
  12. Oct 14, 2016 #11
  13. Oct 15, 2016 #12
    So, in a frame where angular momentum is defined with respect to the nucleus, you can define and measure:
    spin angular momentum of photon (from state of polarization)
    spin angular momentum of initial state of nucleus
    If the end result is a single nucleus (excited state), can the distance between photon and nucleus thereby be defined?
  14. Oct 16, 2016 #13
    vanhees71
    2017 Award
    There's no way to split the total angular momentum of the em. field into spin and orbital angular momentum. Only total angular momentum is well-defined and gauge invariant. There is also no way to define a position observable for a photon (or any massless particle with spin ##\geq 1##).
  15. Oct 16, 2016 #14
    ShayanJ
    You mean its possible for massless spin-## \frac 1 2 ## particles?
  16. Oct 16, 2016 #15
    vanhees71
    2017 Award
  17. Oct 16, 2016 #16
    mfb
    2017 Award
    Staff: Mentor
    Unfortunately we don't know any massless particles with spin < 1. Well, one neutrino mass eigenstate could be massless, but that would be odd.
  18. Oct 16, 2016 #17
    vanhees71
    2017 Award
    True, there's no known massless particle except the photon (note that gluons are confined in hadrons and most likely also glue balls; they never occur as asymptotic free states, as which they were also massless).
  19. Oct 16, 2016 #18
    Does the circular polarization of electromagnetic field depend on observer?
  20. Oct 17, 2016 #19
    vanhees71
    2017 Award
    What do you mean by that? Circular polarizations are states of good helicity, and that's a Lorentz-invariant quantity (for massless fields, as the em. field is!). In that sense it's a covariant charcterization of the field and thus observer independent.
  21. Oct 17, 2016 #20
    So, if you have a photon whose circular polarization/helicity is known, do you also know its spin?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Pair production proximity
  1. Pair production (Replies: 2)
  2. Pair production (Replies: 11)
  3. Pair Production (Replies: 11)
  4. Pair production (Replies: 12)
Loading...
