Exploring Parabolas from Orbital Equations
  • Thread starter KBriggs
  • Tags
    Orbital
In summary, the conversation discusses the derivation of the orbit equation for bodies in inverse square fields. It is shown that the equation can give an ellipse for epsilon values between 0 and 1, but for epsilon = 1 it gives a parabola. However, this is due to a constant in the equation and not a function of epsilon. The conversation also references an article that confirms the correctness of the equation.
KBriggs
33
Hey all
the prof derive the orbit equation for bodies in inverse square fields as:
[tex]r=\frac{a(1-\epsilon^2)}{1+\epsilon\cos(\theta)}[/tex]
Now, I understand how this gives an ellipse for epsilon between 0 and 1, but when epsilon is one, how does this give a parabola? Isn't the equation identically 0 if epsilon = 1?
a is supposed to be the semi-major axis, but that's infinity for a parabola. The product of a and 1-e^2 is actually a constant, equal to h^2/GM where h is the angular momentum per unit mass.
ideasrule said:
That article shows that the OP's equation is correct.
I corrected my post, misread the OP.
Could you show me how that would be calculated? We don't have anything about a being a function of epsilon.
1. What is a parabola?
A parabola is a U-shaped curve that is formed by the graph of a quadratic equation, y = ax^2 + bx + c. It is a conic section, meaning it is created by intersecting a cone with a plane.
2. What are orbital equations?
Orbital equations are mathematical equations that describe the motion of objects in space, particularly around a central body such as a planet or star. These equations take into account variables such as gravity, velocity, and position to model the path of an object in orbit.
3. How are parabolas related to orbital equations?
Parabolas are often used to represent the path of an object in a specific type of orbit known as a parabolic orbit. In this type of orbit, the object's path follows a parabolic shape, with the focus of the parabola being the central body it is orbiting.
4. What can we learn from exploring parabolas from orbital equations?
By studying parabolas from orbital equations, we can gain a better understanding of how objects move in space and how gravity affects their motion. This can help us make predictions and calculations for space missions, satellite orbits, and other related fields.
5. Are there any real-life applications for exploring parabolas from orbital equations?
Yes, there are many real-life applications for this concept. For example, it is used in space exploration to plan and execute missions, in astronomy to study the motion of celestial bodies, and in engineering to design and maintain satellite orbits. It can also be applied in fields such as physics, mathematics, and astrodynamics.
  • Classical Physics
  • Classical Physics
  • Classical Physics
