Can black holes grow if nothing can enter them?
In summary, these three things are all related to the concept of an event horizon. If you are accidentally dropped into a black hole, you will never be able to see anything cross the event horizon. However: -You will experience falling through the event horizon and then reaching the central singularity quickly. -If I try sending you a radio message ("Dude! - I'm sorry! - I didn't mean to drop you! Please forgive me!") you will be able to reply ("You've killed me because you are a clumsy jerk! No, I don't forgive you!") only if I send it before a certain time. After that, you won't get my message until you've
sillycow
I have some questions regarding things that boggle my mind about black holes. These things seem to me like paradoxes, and I was wondering if someone could explain them.
1. How do you measure the distance to a black hole? As far as I understand the distance to a black hole is defined as the distance from an observer to the event horizon. Distance, in physics is defined by the time it takes light from point A to reach point B. However, as time is dilated close to the event horizon, no observer will ever see anything fall into the black hole. An observer would just see things red-shifted and slowing down. Meaning: "Light would take an infinite amount of time to travel *into* the black hole. Wouldn't that mean that the black hole is infinitely far away from any observer? (farther away than things which are "behind" the black hole)
2. This one involves several "paradoxes"
2a. As you approach the event horizon, it keeps moving away from you (space-time gets increasingly curved).
2b. If you look at someone falling towards an event horizon, they slow down until they almost freeze.
2c. That leads me to believe that no observer can ever observe any object to cross an event horizon. How can a black hole come into existence, if it wasn't there beforehand. Or in other words, if nothing can be seen to cross an event horizon for any observer, how can an event horizon exist?
3. Not really a paradox, but a "cool question". If I stand in between 2 black holes (not inside their event horizons), in the exact point where their gravity nulls each-other out. Assuming I am a point particle... Do I get double the time dilation compared to someone standing far away? Or 0 time dialation?
Likes astrophysicskid
As you mentioned the radar distance is infinite. So, instead, the Schwarzschild r coordinate is measured by measuring the circumference around the black hole and dividing by ##2\pi##
Likes Sid Echikson and sillycow
I think there is some circular logic here. Since distance becomes meaningless around a black hole, how would you define circumference? For every circumference defined by "it would take light x seconds to orbit the black hole", I could theoretically find a slightly closer circumference that takes x+1 seconds because of time dilation. That is unless this function converges to some value (That is I cannot find an x+1). Does it? My ballpark hunch says that it doesn't, since at the event horizon itself, light would take forever to orbit the black hole.
I am not sure why you would think that distance is meaningless around a black hole. The geometry is curved, but not meaningless.
The circumference is measured locally. It could be measured using a ring of radars or a ring of rulers, either way is fine. Time dilation is not relevant because all of the measurements involved are at the same gravitational potential.
Likes CrackerMcGinger
This one has been discussed in many other threads here - a search will find some of them.
It is true that if I accidentally drop you into a black hole, I will never SEE you cross the event horizon - the light from that event will never reach my eyes so that I can't SEE it. However:
a) You will experience falling through the event horizon and then reaching the central singularity rather quickly.
b) If I try sending you a radio message ("Dude! - I'm sorry! - I didn't mean to drop you! Please forgive me!") you will be able to reply ("You've killed me because you are a clumsy jerk! No, I don't forgive you!") only if I send it before a certain time. After that, you won't get my message until you've crossed the horizon and it's too late.
c) There is another point in time, only slightly after the one in #b, such that I have to send my message before then or you won't even receive it because you've died at the central singularity before it got to you.
Putting all of these together, it's hard to see how your conclusion in #2c above makes sense. It's much more natural to say that you do in fact fall through the horizon and hit the central singularity - I just don't get to see it.
Gravitational time dilation is not caused by the strength of the gravitational field, but rather by the difference in gravitational potential between the two clocks. Thus, the amount of time dilation between your clock and a clock at infinity will depend on how far away you are from the two masses (which don't need to be black holes - as long as you're outside the event horizon event horizon there's no difference between a black hole and any other massive object). But whatever it is, it will be twice the what you'd get if there was only one mass present and at that distance.
Likes Sid Echikson and Stephanus
Distance doesn't become meaningless around a black hole. What does become meaningless is the distance along any line that passes through the central singularity - and that means the diameter and the radius. However, there's no problem with the tangential directions (as long as the black hole is not rotating - that's a whole new can of worms) so circumferences and surface areas work just fine and that's why we use them.
It is true that even the radial distances that do not cross the central singularity behave strangely, but that strangeness doesn't mean that they're undefined, just that they don't behave the way they would in flat space. Suppose we have two spherical shells around the black hole: the inner one has surface area ##4\pi{R}_1^2## and the outer has surface area ##4\pi{R}_2^2##. In an uncurved spacetime you would expect that the gap between the two spheres would be ##R_2-R_1##, but in the curved spacetime that gap is somewhat larger. That doesn;t make the distance meaningless, it just makes it larger than you'd expect if there was no gravity.
This is the most obvious way to define it, yes. However, there is an important caveat to this definition; see further comments below.
No, it isn't. You can measure distances without using light; use a ruler, for instance.
The current SI unit of distance, the meter, is defined so that the speed of light is exactly 299,792, 458 meters per second, which effectively means it's defined in terms of light travel time. But that's a definition of a unit, not the definition of the concept of distance. Before that SI definition was adopted, the meter was defined in terms of a standard number of wavelengths of a particular atomic emission line; and before that, it was defined in terms of a standard meter stick kept in France.
No; but it does mean that we need to be careful in defining exactly what is meant by "distance to the horizon".
The key point is that the event horizon is not a "place". It's a null surface--a surface formed of radially outgoing light rays. That means nothing can "stand still" at the horizon, so you can't put one end of a ruler at the horizon and the other end at a chosen point outside and measure the distance between them--the end of the ruler at the horizon would have to move outward at the speed of light, like the light rays that form the horizon. (The reason these light rays don't actually increase their radial coordinate, even though they're moving outward at the speed of light, is that spacetime at the horizon is curved just enough to keep them at the same radial coordinate.)
To rigorously define the distance along a radial line to the horizon, what you need to do is envision a limiting process, where we imagine a series of rulers with their upper ends at our chosen point, and whose lower ends approach the horizon more and more closely. We then define the distance to the horizon as the limit of the lengths of those rulers as the radial coordinate of their lower ends approaches the radial coordinate of the horizon. This limit can be computed mathematically, and it is finite, so it can serve as a definition of a finite "distance to the horizon" from any point outside the horizon.
Likes sillycow
There are complications lurking here that need to at least be mentioned to avoid giving a wrong impression. As my previous post shows, distance along any radial line can be defined outside the horizon; and by using an appropriate limiting process, radial distance to the horizon from any point outside can also be defined.
What can't be defined is distance of this kind inside the horizon. That is because inside the horizon, spacetime is not static; you can't think of a particular radial coordinate ##r## inside the horizon as marking a "place in space" so that you can measure distances between two different ##r## coordinates. So even the idea of a radial line that passes through the singularity is meaningless (let alone distance along such a line); there is no static "space" for such a line to pass through. So a black hole doesn't even have a diameter or a radius in the usual sense. Another way of putting this is to say that the singularity is not a place in space; it's a moment of time (and this moment is to the future of any event inside the horizon).
(Even the above doesn't completely cover all the complications lurking here, but I'll stop now since this is a "B" thread.)
Thanks for taking the time guys, I really appreciate it.
@PeterDonis, Here is what I don't get.: You can define distance in several ways. For example, as you have suggested, let's use a ruler instead of light.
So let's say that we are using 1 meter rulers to make things simple.
If we defined "distance" relative to the length of said rulers, how can we say that the "distance" converges? (distance is in quotes, because I am starting to feel that the word is getting "mushy" on me :-). ) . If there are infinite rulers, and a unit of length is a ruler, then doesn't that mean that the distance is diverges to infinity instead of converging to some value? Would the 100th ruller disappear (besides growing fainter)?
I realize that as they approach the event horizon, rulers will seem "shorter" and fainter. (I also realize that at some quantum point "fainter"=="does not exist anymore", but let's ignore quantum mechanics, as that just makes it more complicated). However, notice that "shorter" is in quotes: If I defined rulers as my unit of distance, how can I say that they are "shorter"?
Is there a definition of "distance" for which this doesn't happen?
R1 and R2 are such distances (they pass through the black hole). I can however deduce them by measuring circumference: R=C/2Pi. I would measure this circumference using the amount of time it takes an object to orbit it. That way I can deduce R2. However, as I approach the black hole wouldn't the object start orbiting more and more slowly because of time dilation, thereby making the circumference paradoxialy larger? Or would it only accelerate more slowly thereby giving me a limit?
I have read, and perhaps misunderstood, that objects traveling towards the black hole seem to freeze in time on it's surface, because their time slows down. If their time slows down, wouldn't their orbit slow down as well? Or would the acceleration caused by gravity "even out" with time dilation cause the orbit speed to converge to a fixed speed? If so, then I see how I would deduce a limit on the radius. Is this the case?
To reiterate: If R1 is behind R2 (I have to pass R2 to reach R1) is R1 allways shorter than R2 ? Geomtrically speaking, can a black hole be curved like an "hourglass"?
They are not distances, they are just numbers that we've calculated. The circumference is a distance because I can measure it the old-fashioned way using a meter stick; but the number I calculate from ##R=C/2{\pi}## isn't the distance between anything and it doesn't "pass through" anything. It's just a number that pops out of the calculation.
I would measure this circumference using the amount of it it takes an object to orbit it.
You can, but you could also (in principle) actually build the spherical shell around the black hole, land your spaceship on the surface of the shell, and use an ordinary meter stick and similar tools to directly measure the distance around the circumference pf the shell. That way you can be sure that you really have measured the circumference, with no complications from time dilation, orbital dynamics, and the like.
To reiterate: If R1 is behind R2 (I have to pass R2 to reach R1) is R1 always shorter than R2?
If the spherical shell whose area is ##4\pi{R}_1^2## is inside the spherical shell whose area is ##4\pi{R}_2^2##, then ##R_1\lt{R}_2##. That's "less than", not "shorter" - they're numbers, not the lengths of anything, so "longer" and "shorter" aren't words that apply here.
I am not sure how you would change that into a measure of distance. You would have to assume some relationship between the orbital period and the circumference of the orbit. You could certainly do so, but it would be as much a measurement of the mass as a measurement of the circumference.
Why not directly measure the circumference using rulers or radar as mentioned above?
From http://www.mathpages.com/rr/s7-03/7-03.htm (Falling Into and Hovering Near A Black Hole) -
'..relative to the frame of a particle falling in from infinity, a hovering observer must be moving outward at near light velocity. Consequently his axial distances are tremendously contracted, to the extent that, if the value of [itex]\Delta r[/itex] is normalized to his frame of reference, he is actually a great distance (perhaps even light-years) from the r=2M boundary, even though he is just 1 inch above r=2M in terms of the Schwarzschild coordinate r. Also, the closer he tries to hover, the more radial boost he needs to hold that value of r, and the more contracted his radial distances become. Thus he is living in a thinner and thinner shell of [itex]\Delta r[/itex], but from his own perspective there's a world of room...
Quantitatively, for an observer hovering at a small Schwarzschild distance [itex]\Delta r[/itex] above the horizon of a black hole, the radial distance [itex]\Delta r'[/itex] to the event horizon with respect to the observer's local coordinates would be-
[tex]\Delta r'=\frac{\Delta r}{\sqrt{1-\frac{2M}{2M+\Delta r}}}[/tex]
where [itex]\Delta r'[/itex] is proper distance, [itex]\Delta r[/itex] is coordinate distance and [itex]M=Gm/c^2[/itex]
Likes sillycow
Didn't want to change the observer's position by coming closer to the black hole. Having something orbit the black hole at the speed of light seemed "cleaner", as I could measure how many times that object revolves around the black hole without comming any closer myself.
This depends on how space-time is curved. In a torus (mmm... doughnuts.. :-) ) curvature ,this can be untrue. A bigger circular circumference could be placed "inside" a smaller circumference. Where "A is inside B" means that you have to pass through a to get to B. So "inside" and "contains" are not directly related to sizes,lengths,areas,and volumes.
That's true, but you started you this thread asking about one particular way that space-time is curved, namely what you find around a black hole (actually, any spherically symmetrical mass, whether a black hole or not - the effects we're discussing here happen around the Earth as well, but are so weak we seldom notice). That curvature is given by the Schwarzschild solution to the equations of general relativity, and it does behave as I describe.
You also asked earlier
Geometrically speaking, can a black hole be curved like an "hourglass"?
The best way of visualizing the spatial curvature around a black hole is 'Flamm's paraboloid' - google will find many good references. However, it comes with a few cautions:
1) Flamm's paraboloid illustrates curved space, not curved spacetime. It's accurate but incomplete, just as a two-dimensional cross section of the Earth through the equator will show that the Earth's surface curves as you travel east or west, but doesn't show the north-south curvature.
2) Do not just look at a picture of the paraboloid and think "OK now I get it" - that almost guarantees that you will misunderstand what you're looking at. You have to read and understand the math that comes with it to understand what you're looking at.
(and a digression: although the surface of a physical doughnut is curved, it turns out that the surface of an ideal mathematical torus is actually flat. This is a digression so no need to follow up, but if you want to, googling for "intrinsic vs extrinsic curvature" will get you started).
Likes sillycow
1) Flamm's paraboloid illustrates curved space, not curved spacetime. QUOTE]
Thanks Guys! I have a lot to read now.
sillycow said:
Could you explain the difference between "proper distance" and "coordinate distance"?
Is "Proper distance" what the faller is obeserving, vs "coordinate distance" being what a fixed outside observer would observe?
This is correct (though it's not a 'faller', it's a static observer).
"Converges" is a technical term; it just means we are taking a limit as a particular parameter (in this case, the radial coordinate of the lower end of our measuring device) approaches a particular value (in this case, the radial coordinate of the horizon). If my use of the word "ruler" is confusing you (because the length of the "rulers" in question varies), think of it this way: we have a tape measure with one end fixed at a particular point above the horizon. We slowly extend the tape measure so that its other end approaches the horizon. The distance registered by the tape measure, which is defined in terms of how many standard rulers it takes to extend from one end of the tape measure to the other, will increase slowly, and as its other end gets closer and closer to the horizon, the distance registered will approach some particular finite value--it won't increase to infinity. That finite value is the distance to the horizon. We can't actually put the other end of the tape measure at the horizon, for the reasons I gave in my last post; that's why, to be careful and precise, we have to phrase things in terms of the limiting process I just described.
Likes sillycow
Hi, I am still reading stevebd1's link. However this thought experiment has me vexed:
To paraphrase: Say I am standing outside the black hole, and I drop a chain of 1m rulers towards it in freefall. (Thereby eliminating any rigidity of said tape measure and dividing it into discrete units, ). I let the black-hole accelerate them towards it by pulling them with it's gravity. I have an infinite amount of rulers to drop. If the distance is to converge to some fixed number, then one of the following needs to happen:
1. At some point I will see the first ruler I dropped disappear into the black hole.
or
2. At some point I will see two rulers overlapping: One's front end will pass the other's back end.
I gather that both of these things would happen at the event horizon: The rulers overlap because they are in singularity & They disappear because light cannot escape. However, I have read that no matter how much time I wait, I will never observe the rulers crossing the event horizon. So from my point of view, I can keep on dropping an infinite amount of rulers. and hence my problem with convergence. That is unless I actually see them overlap or disappear beforehand.
There is no singularity at the event horizon. As for 'seeing' it depends who is 'looking'. Each of the falling rulers (granted eyes), will see the ruler in front remaining a 'normal' distance in front of it, same for ruler in back, until nearing the singularity well inside the horizon. A observer hovering a distance outside the horizon will see the distance between rulers getting ever smaller, and they will be red shifted such that they become invisible on approach to the horizon. Given any sensitivity of detector for the hovering observer, no matter how good, the rulers will each 'disappear' fairly quickly - but this will happen just outside the horizon.
The upshot: both of your choices are wrong. No one outside will see a ruler cross the horizon, nor will they see any overlap.
Then the rulers will be moving relative to you, so they will be length contracted relative to you--even leaving out any effects of spacetime curvature. So you won't be able to use them as a standard of length.
All this will do is increase the amount by which the rulers are length contracted relative to you. But pretty soon, the rulers will be out of your local inertial frame anyway, and there won't be any meaningful way for you to measure their "length" relative to you.
or
#1 will sort of happen--see further comments below. #2 will not. In fact, the rulers will diverge as they fall; that is, between any two adjacent rulers, a space will open up and get wider as they fall. This is an effect of tidal gravity. Depending on how close you are to the black hole and how accurate your measuring devices are, you may be able to see this happen (after you correct for distortion--see below) before a given pair of adjacent rulers fall below the horizon.
No, just #1. See above.
The event horizon is not a singularity; all physical quantities are perfectly finite there. The singularity is at ##r = 0##, inside the horizon. (More precisely, once you fall inside the horizon, the singularity is in your future, no matter what you do.)
That's correct. But you will observe light from them rapidly redshift to a point where you can't detect it any more. You certainly don't see them continuing to fall through an infinite distance.
However, the more complete response to what you have said is: "So what?" Who cares whether or not you can observe the rulers dropping below the horizon? All that means is that, at some point, light emitted by the rulers can no longer reach you. It says nothing at all about what happens to the rulers after that point.
Sure, but every one of them covers the finite distance to the horizon and then disappears, as far as you're concerned. Nothing you have stated is in any way inconsistent with the distance to the horizon being finite.
If you actually saw the rulers continuing to fall through an infinite distance, that would indeed contradict the claim that the distance to the horizon is finite. But you don't see that. What you see, if we assume for a moment that you can detect light of arbitrarily long wavelength, is the rulers getting shorter and shorter as they get closer and closer to the horizon, and moving more and more slowly.
Note that the above is just what you see; it's not what someone falling along with the rulers would see. What you see is distorted by spacetime curvature, and in order to figure out what is happening at the rulers themselves, you first have to correct for the distortion. Since the distortion becomes infinite at the horizon, the corrections become arbitrarily large as you get closer and closer to the horizon; that's why you can see what I described above while the distance to the horizon is still finite.
No, the problem is that you are trying to measure "distance to the horizon" by a method that doesn't work. See above.
It's worth being careful in stating this, in order not to confuse the effects of the distortion I mentioned in my previous post, with the effects of tidal gravity. Tidal gravity increases the separation between adjacent rulers, as I said; but because of the distortion, the apparent distance between adjacent rulers, viewed by someone hovering at a fixed altitude, does decrease (as does the apparent length of each ruler itself).
True enough, but I focused exclusively on 'seeing' per my interpretation of the post I was replying to. We obviously agree on what the hovering observer visually sees.
That won't eliminate the rigidity concern - even if you let your end of the tape measure move freely instead of holding on to it, the stresses along the tape will increase without bound. This is because of the tidal forces, which ensure that it's not possible for all parts of the tape to be in free fall without moving away from one other.
Thus, we might as well simplify the problem by assuming that the tape is strong enough that we can hold the upper end fixed as long as the far end hasn't passed through the event horizon yet. The stresses in the tape will be very large if the far end is close to the horizon, but they will not be infinite until the far end goes through the horizon (and remember what I said in #5 above about how the far end really can be lowered below the horizon even if you never see it happen).
BTW, thanks again for taking the time to untangle my thoughts.
Yes, It does. This is at the heart of what's twisting my brain :smile: : At the beginning of the thread, I suggested using the speed of light as a definition of distance. However it was suggested that I use rulers instead. If a ruler *is* the definition of "length", and I observe it to be "relitivisticly contracted", then I observe "length" to be "reletavisticly contrated". The definition of length was arbitrary, I could have used anything else. But with the definition of length being rulers, seeing 2 rulers should mean a length of exactly 2 (remember we're not using light years as a measurement, but rulers which were measured to be identical by the same observer). Even if later they seem to be different, the length is still: two identical rulers. I think that the conclusion should be that rulers and tape measures are not good measurements of distance.
However, if we continue with the ruler analogy, if the "printed length" on the rullers (the centimeter marks), never converge. How can you say that the length of the tape measure converges? To put it in "greek geometry": Whatever length tape measure you choose, I can always choose one that's a much longer, and I would still not it reach the event horizon. (Or is "planck length" considered "touching"?)
I would like a more precise definition of "can't detect". I would like to differentiate between "can't detect" and "hard to detect". Even 1 photon every billion years should be "detectable", it's just very hard. At some point, do I encounter some quantum phenomenon that makes it so that the observer "can't detect"?
A ruler at rest in some frame of reference, defines distances in that frame.
Likes PeterDonis
I think I finally understand it. If I stop using tape-measures and rulers to define length, and go back to using the speed of light...
1. I drop a mirror with a clock towards a black hole.
2. I fire a laser at the mirror.
3. I measure the amount of time it took the laser to return to me.
The results should be that:
When examaning the time it takes for the laser to reflect off the mirror, this time converges to some fixed value. This happens because to me as an observer, I see the mirror decelerating as it aproaches the black hole.
I would however still like an explanation for "cant' detect" (as quoted above). I gather there is some interesting quantum phenomenon that I am overlooking.
The ruller is a further abstraction on the tape measure. It was said that a tape measure's length would converge on some value. The length of the tape measure is determined at rest. That's when they print the markings on it at the factory. As such, it's length would not converge, but rather diverge. (The thread started out with "how do you define distance?")
There is no need to invoke any quantum mechanical phenomenon here. The redshift becomes arbitrarily large (the intensity of the light becomes arbitrarily small) as the object emitting the light gets arbitrarily close the event horizon. No matter how sensitive your detector, I can always move the object a bit closer to the horizon and it will become undetectable to that detector. Therefore, no matter how sensitive your detector is, there will be some point somewhere above the horizon at which the emitted light cannot be detected. If you improve the sensitivity of the detector, then that point will be closer to the horizon... But no matter how good your detector is, there will always be some point between the object and the horizon beyond which the detector won't be able to detect. Thus, no imaginable detector will be able to detect all the way down to the horizon.
You are right that there is a difference between "hard to detect" and "impossible to detect", but "arbitrarily hard to detect" actually means "impossible to detect". It's a lot easier to prove this rigorously after you've been through a calculus class though.
That's not what happens. Instead, as the mirror gets closer to the event horizon the return time for the laser light increases without bound; this is just another way of saying that you'll never see an object falling through the horizon. You can still calculate the distance to the mirror using the time it takes for the light to reflect off the mirror, but the calculation is a lot more complicated than just dividing the time by ##c## and it stops working completely as the object reaches the horizon (because the laser light never makes it back to you so you never get a time measurement).
  • #31
I would have to divide by 2C as the light travels in both directions, and what are the complications? Does anything else take time besides the passage of light through space? Does it take time for the mirror to locally start reflecting light? I do not understand?
I thought according to the theory of relativity, every observer allways sees light traveling at C relative to herself. Isn't that the whole point of space-time dialation: Light travels at the same speed, but it's time-space being warped.
This is not the only solution to "I'll never see an object fall through an event horizon". The other is saying that I'd see the object slow down, and *almost* freeze at the horizon's "distance". As such it keeps getting closer at an ever slower rate. But it's distance to me is not "without bound", as there is an analytical solution to the limit.
How can you say this after saying:
If no observer can ever observe anything reaching an event horizon? I mean, it would literally take forever to see something reach an event horizon. So how can you say that observer A can ever see anything stop emitting light "as the object reaches the event horizon"? I mean there can exist no object B which an outside observer, A, can ever witness falling past an event horizon. Can something "happen", if no-one can ever witness it, or be affected by it? Isn't that the "philosophy" of singularities? Namely: what you can't observe is meaningless.
  • #32
Let's not get into philosophy here. GR predicts that there are classes of observers that can witness it and it predicts what other classes of observers will witness. That is scientifically sufficient.
  • #33
So far we have dealt with 2 classes of objects:
One that does not accelerate: This is the observer. (is it standing still? Is it orbiting the black hole, or being pulled inside at a lower speed?, I'm not sure that it matters [does it?]).
The other object starts moving wit a higher speed towards the black hole. This is the mirror
They both start out at the same point.
We know that this class of observer would ever never observe the mirror to reach the horizon. (it would take infinite time)
We know that the mirror would not observe itself reaching the horizon, because the horizon keeps "backing off" from it.
So this "class" of observer cannot see it happen.
Can you define a different class of observer that would see the mirror reach the event horizon.
  • #34
Yes. The class of observers that also cross the horizon.
  • #35
It's probably worth pointing out that if you fall into a BH with any kind of velocity then the radial length expansion is reduced and in the case of falling from rest at infinity, when your velocity would be [itex]v=\sqrt(2M/r)[/itex], then (rudimentally) the length contraction (due to SR) would cancel out the length expansion (due to GR, i.e. gravity) and coordinate distance would equal proper distance from the perspective of the infalling observer. This is taken into account with Gullstrand Painleve coordinates, it also removes the singularity at the event horizon. Basically the view of the BH would be very different for an observer hovering above it and for an observer falling in with some speed.
