Homework Help: Parallel LR impedance
  1. May 4, 2017 #1
    Find the complex parallel impedance of a 20 Ω resistor and 110 mH inductor from a 50 Hz supply.
    2. Relevant equations
    Z = R (XL2 / R2+XL2) + j XL (R2 / XL2 + R2)
    3. The attempt at a solution
    R = 20 Ω
    XL = j34.6 Ω
    Z = 20 ( j34.62 / j34.62 + 202) + j34.6 ( 202 / j34.62 + 202) Ω
    Z = 20 ( -1197 / 400 - 1197 ) + j34.6 ( 400 / 400 - 1197 ) Ω
    Z = 30 - j17 Ω
    Apparently this is wrong but I can't find where I have gone wrong.
    Thanks
  3. May 4, 2017 #2
    BvU
    2017 Award
    Hi,
    Not clear where your relevant formula comes from.
    Why not simply $${1\over Z} = {1\over R} + {1\over j\omega L}\ \ ?$$
  4. May 4, 2017 #3
    BvU
    2017 Award
    Correction: I confirm your equation, so it's in a later step. Check out what XL should be.
  5. May 4, 2017 #4
    I calculated XL at 50 Hz and got j34.6 Ω
    Then I tried to calculate XL2 as follows:
    XL2 = (j34.6)2 = -1197
    Are you suggesting -1197 is incorrect?
    Thanks for your response.
  6. May 4, 2017 #5
    BvU
    2017 Award
    I am indeed. The complex impedance is ##{\bf j}\omega L## but the reactance XL is a real number.
  7. May 4, 2017 #6
    I've been sat trying to interpret what you said and getting nowhere unfortunately. 34.6 is a real number? 34.62 = 1197
  8. May 5, 2017 #7
    BvU
    2017 Award
    So XL2 is 1197, not -1197. Indeed.
    And: be clearer with the brackets when you write down an expression.
  9. May 5, 2017 #8
    Right I understand what you are saying and thanks for the help.
Have something to add?
Draft saved Draft deleted
