1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Parallel plate capacitor
  1. Mar 12, 2008 #1
    tony873004
    A parallel plate capacitor with A=125 cm2 and d=1.25 mm is charged to a potential difference of 10.0 V. What is the charge density on each plate?
    2. Relevant equations
    [tex]
    V = \frac{{\sigma d}}{{\varepsilon _0 }}\,\,\,\, \Rightarrow \,\,\,\,V\varepsilon _0 = \sigma d\,\,\,\, \Rightarrow \,\,\,\,\sigma = \frac{{V\varepsilon _0 }}{d}
    [/tex]
    3. The attempt at a solution
    Plugging in numbers, I get 8.5*10-8C/m2. But I never used the Area. My units seem to work. Did they throw in irrelavant data? Shouldn't I only need Area if I want total charge?
    Should my answer be half of what I computed, because it is divided between 2 plates?
  3. Mar 12, 2008 #2
    Hootenanny
    Staff Emeritus
    As far as I'm concerned your solution is correct. As you correctly point out, one only needs the area to calculate the total charge on each plate. Further, you do not need to halve your answer since the surface charge density is calculated for each plate. You can check your solution by placing a Gaussian surface around one plate. Perhaps http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elesht.html#c2" would be helpful.
  4. Mar 12, 2008 #3
    tony873004
    Thanks for the feedback and the link!
Similar Discussions: Parallel plate capacitor
Loading...
