Parallel RL Circuit: Get Help with AC Supply & Differential Equation
In summary: Yes, you can use this method for any order of ODE. For the general solution of a second order ODE, you need to find two coefficients, as you said. These coefficients will depend on the initial conditions of the problem. To find them, you can use the initial conditions of the problem and the derivatives of the functions of the general solution. I'm not sure if I'm explaining myself very well, it's a little difficult to explain without being able to draw the equations. I hope you understand me. Don't worry about asking questions, that's how we learn! :smile:Okay!thanx a lot for all the help!you have been really patient!I
ng
31
Hi there,
Can someone help me with parallel RL circuit across ac supply?wats the differential equation ...
Thanx for all help.
ng
  • I.doc
Try this - http://www.play-hookey.com/ac_theory/ac_rl_parallel.html to start.
Thanx for the response.I have already seen that and din help me much.
The problem is with getting the transient solution.
RC parallel -If the input is Vcoswt then current throu R will be V/Rcoswt.throu C is
-CwV sinwtThis is te steady state i understand.But the transient and getting to it throu te differential equations is my problem for both RL and Rc parallel across ac supply.
In the doc file, you have a differential equation.
V = VR(t) = VL(t) = L [itex]\frac{di(t)}{dt} [/itex] = ( I(t) - i(t) )/R,
but I(t) = V(t)/R + i(t), and let i(t) = VL/ZL where Z is the impedance.
Also consider i(t) = io cos ([itex]\omega[/itex] t + [itex]\theta[/itex]), where [itex]\theta[/itex] is the phase angle.
The voltages are in phase, the currents are out of phase.
Evaluate at time, t = 0.
See if that helps.
In your attached file you have already arrived to the differential equation, you just didn't write it in a form to solve it. Write your equation as:
[tex]L\frac{di}{dt} + Ri = RIcos\omega t[/tex].
This is a non homogeneous differential equation. Find the solution of the homogeneous equation iH(t) and a particular solution that will be of the form iP(t) = Acos(ωt + φ).
The general solution is i(t) = iH(t) + iP(t)
Replacing the initial conditions you have the solution. It contains two terms: the exponential term is the transient and the cosine term is the steady state.
hey sgt,thankyou for that reply.yeah,how stupid of me...u r right.
thanx again.
For your last circuit. I started it out like this,
Apply KCL at the top supernode and you have
[tex]I_{in} = i_R + i_L + i_c[/tex]
Note, that all cicuit components have the same potential and recall that
[itex]L \frac {di_L}{dt} = v_L[/itex] and [itex]C \frac {dv_c}{dt} = i_c[/itex]
thanx for the reply, corneo
hmm... okay.but i was wondering why shud i assume the solution
Acos(wt+Phi)?
Is this what is assumed for first order circuits subject to ac supply?i read its Acoswt+Bsinwt for second order circuits.am i right?
:confused:
You should assume the solution is [tex]A \cos (\omega t + \phi)[/tex] because I think your going to use methods of undetermined coefficients. I think cosines and sines appear in your solution to 2nd order ODE because the circuit is underdamped ([itex]\zeta < 1[/itex]). I just took a class in circuits so a lot of this is still new to me.
Thankyou corneo,
Okay
so i get
Ldi/dt+Ri=RIcoswt
to get the complementary solution assume
Ldi/dt+Ri=0
int di/i=- intR/L dt
ln i= -R/Lt+K
i=exp(-t/tau+k)
at t=0 initial condition i is V/R
then its..?is it right?
for particular solution i assume i=Acoswt
putting in first eqn
-Lwsinwt+RAcoswt=RIcoswt...
where am i going wrong?
please help.
Acos(wt+Phi)?
:confused:
Both solutions can be used with first and second order circuits (or higher orders). They are equivalent.
[tex]Acos(\omega t + \phi) = Acos\omega t cos\phi - Asin\omega t sin\phi = A_1 cos\omega t + A_2 sin\omega t[/tex]
where
[tex]A_1 = Acos\phi[/tex]
[tex]A_2 = -Asin\phi[/tex]
Okay i get it.thanx SGT.
but ...heheh :biggrin: how do u find the value of A?
You replace the solution and its derivative in the differential equation. When expanding the sine and the cosine of [tex]\omega t + \phi[/tex], you will have in both members of the equation terms in sine and in cosine. Equalling the coefficients of like terms you get the two unknowns A and [tex]\phi[/tex].
SGT,Thanx again ALOT!
So,
Ldi/dt+Ri=RIcoswt
equating the coefficients on LHS and RHS
looks like i am going wrong...is it?
please help.
So,
Ldi/dt+Ri=RIcoswt
please help.
No, you put [tex]i = Acos(\omega t + \phi)[/tex]
or [tex]i = Acos(\omega t) + Bsin(\omega t)[/tex]
calculate [tex]\frac{di}{dt}[/tex]
and replace i and [tex]\frac{di}{dt}[/tex] in the equation.
:smile:
SGT...thanx a million.
i hope i am right this time...
-L(Awsinwt+Bwcoswt)+R(Acoswt+Bsinwt)=RIcoswt
(-LBw+RA)coswt=RIcoswt
-LBw+RA=RI
-LAw+RB=0
solve this to get A and B
w=2 pi f
this approach is used for second order also right?
thankyou once again! :approve:
:biggrin: just one more question...
why can't it be Acoswt?why the phi?
why shud it be coswt?why not sinwt?
(am i being really stupid? :rolleyes: )
When you differentiate cosωt you get -sinωt. If you replace both in the equation you get a term in sinωt in one side that must be equalled to zero on the other side, this is inconsistent. Just try it in your equation and you will see.
Of course you can use the sine instead of the cosine, they are the same function, only with different phases.
cosωt = sin(π/2 - ωt)
okay i understand.
Is this used in second order equations as well?
hmm... an underdamped case for instance
there r two coefficients in it right?
how is that found?
i hope i am notgetting onto ur nerves!
thankyou for all the help.
ng said:
okay i understand.
how is that found?
Both in first and second order equations the steady state response to a sinusoidal input have two parameters to be evaluated: A and φ or A1 and A2.
You have two equations: one with the coeficients of the terms in sine and one with the coeficients of the terms in cosine. Two equations, two unknowns ...
thanx for the quick response.
For example,
The overdamped case has the solution
v=A1exp(s1t)+A2exp(s2t)
and the equation is of the form
series rlc
L d^2i/dt +Rdi/dt +i/C=dV/dt
cud u please help me?
For example,
series rlc
The solution you gave is of the homogeneous equation. The total solution is the sum of iH and iP.
[tex]i = A_1 e^{s_1 t} + A_2 e^{s_2 t} + K cos(\omega t + \phi)[/tex]
yes,but how to find the values of A1 and A2?
You obtain the derivative [tex]\frac{di_L}{dt}[/tex] and then replace the initial values [tex]i_L (0)[/tex] and [tex]\frac{di_L}{dt}(0)[/tex] in the equations.
V=Acos(wt+phi)=Acoswt+Bsinwt
i=A1exp(s1t)+A2exp(s2t)
di/dt=s1A1exp(s1t)+s2A2exp(s2t)
d^2i/dt^2= s1^2A1exp(s1t)+s2^2A2exp(s2t)
i(0)=V/R
if its dc dV/dt=0
ac then dV/dt=-Awsinwt+wBcoswt
is this going wrong?
i(0)=V/R
if its dc dV/dt=0
It's wrong!
i(0) is the current in the inductor prior to the application of the excitation.
[tex]\frac{di}{dt}(0)[/tex] is the derivative of the current in the inductor prior to the application of the excitation.
Since [tex]v_L(t) = L\frac{di}{dt}[/tex], we can say that
[tex]\frac{di}{dt}(0) = \frac{v_L(0)}{L}[/tex]
I am sorry but I donno how to go abt with the equations.
What part of the equations you don't understand?
how u get the steady state and coomplementary solution.
i understood quite a few things from ur replies but not how to reach the
final equations.i am going wrong whenever i try it.
so cud u please help out?thanku again
The steady state solution is of the form:
[tex]i_P = K cos(\omega t + \phi) = A cos \omega t + B sin \omega t[/tex]
You differentiate it two times and replace [tex]i_P[/tex] and its two derivatives in the differential equation:
[tex]L\ddot i_P + R\dot i_P + \frac{i_P}{C} = \frac{dV}{dt}[/tex]
You can calculate the two unknowns: [tex]K[/tex] and [tex]\phi[/tex] or [tex]A[/tex] and [tex]B[/tex].
You have the solution of the homogeneous equation, for instance in the overdamped case:
[tex]i_H = A_1 e^{s_1 t} + A_2 e^{s_2 t}[/tex].
The general solution is:
[tex]i = i_H + i_P = A_1 e^{s_1 t} + A_2 e^{s_2 t} + K cos(\omega t + \phi)[/tex]
You differentiate it to get [tex]\dot i[/tex]
In order to calculate [tex]A_1[/tex] and [tex]A_2[/tex] you must have the initial values of the current and its derivative: [tex]i(0)[/tex] and [tex]\dot i(0)[/tex]
You make t = 0 in the equations of the current and its derivative and set them to the initial values. You have two equations in two unknowns.
  • #31
SGT,Thankyou very much indeed.
I think i got the stuff in my head atlast.
Thankyou. :smile:
  • #32
but then sgt,i also read that ip shud be assumed as
acos(wt+phi) + bsin(wt+phi)
not Kcos(wt+phi) as the supply is Vcos(wt+phi).they need not be in phase...
i am confused now.
  • #33
i am confused now.
No, you make
[tex]i_P = K cos(\omega t + \phi_1)[/tex]
where [tex]\phi_1 \neq \phi[/tex]
if you make
[tex]i_P = A cos \omega t + B sin \omega t[/tex]
the phase angle [tex]\phi_1[/tex] will be automatically calculated:
[tex]A = K cos \phi_1[/tex] and [tex]B = K sin \phi_1[/tex]
  • #34
okay sgt,now i get it.
thanx a loooooooooooooot!
1. What is a parallel RL circuit?
A parallel RL (resistor-inductor) circuit is a type of electrical circuit where the components are connected in parallel, meaning they share the same voltage but have different current paths. It consists of a resistor and an inductor connected in parallel, with an AC power supply providing the voltage.
2. How does an AC supply affect a parallel RL circuit?
An AC (alternating current) supply provides a constantly changing voltage to the circuit, which causes the current to fluctuate as well. In a parallel RL circuit, the inductor causes a phase shift between the voltage and current, resulting in a different behavior compared to a purely resistive circuit.
3. What is the differential equation for a parallel RL circuit?
The differential equation for a parallel RL circuit is dI/dt + (R/L)I = (1/L)V, where I is the current, R is the resistance, L is the inductance, and V is the voltage. This equation describes the relationship between the current and voltage in the circuit.
4. How can I solve a parallel RL circuit using differential equations?
To solve a parallel RL circuit using differential equations, you can use the above equation to find the current as a function of time. You can then use this current function to find other important quantities, such as voltage and power, in the circuit.
5. What are some real-world applications of parallel RL circuits?
Parallel RL circuits are commonly used in electronics, such as in power supplies and audio amplifiers. They are also used in AC motors and generators, as well as in electrical power distribution systems. In addition, parallel RL circuits are used in various scientific and engineering fields for modeling and analyzing dynamic systems.
  • Electrical Engineering
