Parameter for a saddle point
In summary, the first question deals with finding a relation between Lz and Lx, Ly by using the Pythagorean theorem. The second question involves finding the values of current and other parameters in order for the system to reach a saddle point, but more information is needed to provide a solution.
enot
Hello, this is my first post here, so if I do problems, please correct me and do not be upset = )
I have one small theoretical and one greater question.
small one first:
I have a potential energy :
$$W(L)= -\frac{1}{4}k_4(L_x^4+L_y^4+L_z^4)$$
How can describe my potential, replacing L_z with L_x,L_y.
My question is: what the situation should be, that I can replace L_z with L_x, L_y
$$W(L)= -\frac{1}{4}k_4(L_x^4+L_y^4+L_z^4)$$,
k_4 - constant
I thought to write something like :
L_x_tilda^2 + L_y_tilda^2 + L_z_tilda^2 = constant(scalar)
L_x_tilda = (L_x + L_x(0))
L_y_tilda = (L_y + L_y(0))
L_z_tilda = (L_z + L_z(0))
if my special point is L(0) is (0,0,1) then:
L_x^2 + L_y^2 + L_z^2 + 2L_z L_z(0) = 1
1 + 2L_z L_z(0) = 1;
but what does it mean. I do not know. I stuck on this...big one
I have a potential energy again :
I have a system of diff. eq. that describe movement of a part(now without a z dimension)
$$ \ddot{L_x} = - \omega_{af}^2 L_x - 2 \gamma_{af} \dot{L_x} - j L_y $$.
$$ \ddot{L_y} = - \omega_{af}^2 L_y - 2 \gamma_{af} \dot{L_y} + j L_x $$.
where j - is the current ,
My question is: how can I find the value of a current, and other parameters like \omega_{af} , \gamma_{af} so that my system will go to the saddle point.
the idea is here the following I solve the system by naming
L_x = A exp(iwt)
L_y = Bexp(iwt)
then I gather
$$ - A w^2 e^{iwt}= - \omega_{af}^2 A e^{iwt} - 2 \gamma_{af} A iw e^{iwt} - j B e^{iwt} $$
$$ - B w^2 e^{iwt}= - \omega_{af}^2 B e^{iwt} - 2 \gamma_{af} B iw e^{iwt} + j A e^{iwt} $$
then I get the following :
$$ (( w^2 - \omega_{af}^2 - 2 \gamma_{af} iw )^2 + ( j p_z )^2 )B= 0 $$
and I solve such equations:
$$w^2 - \omega_{af}^2 - 2 \gamma_{af} iw = - i j $$
$$w^2 - \omega_{af}^2 - 2 \gamma_{af} iw = i j $$
So for the first eq. I get
$$w = \gamma_{af} i \pm \sqrt{ (- \gamma_{af}^2 + \omega_{af}^2 - i j)} $$
Then I use De Moivre's formula
$$ z^n = |z| ^n \exp(i \phi n)$$
$$\sqrt { |z| } = \sqrt[4] { (- \gamma_{af}^2 + \omega_{af}^2)^2 + ( - j )^2 }$$
if current is small
$$\sqrt { |z| } = \sqrt {- \gamma_{af}^2 + \omega_{af}^2}$$
and
$$\phi = \arctan \frac {b}{a} = \arctan ( \frac { - j p_z} {- \gamma_{af}^2 + \omega_{af}^2} ) $$.
and as $$\omega_{af}, \gamma_{af} > 0$$, $$\gamma_{af}^2 \ll \omega_{af}^2$$ we get:
$$\phi = \arctan ( -\frac { j } { \omega_{af}^2 } ) $$
$$j \ll \omega_{af}^2$$ and $$\tan (\phi) = \frac {-j} {\omega_{af}^2} \approx \phi $$
$$ \exp(\frac {i \phi} {2} ) \approx 1 + \left( \frac {i \phi} {2} \right) + O\left( \left( \frac {i \phi} {2} \right)^2\right) $$
$$ \exp \left( - \frac {i j} {2\omega_{af}^2} \right ) \approx 1 + \left( - \frac {i j} {2\omega_{af}^2} \right) + O\left( \left( - \frac {i j} {2\omega_{af}^2} \right)^2 \right) $$
$$ \sqrt z = \sqrt{ (- \gamma_{af}^2 + \omega_{af}^2 - i j p_z)} = \omega_{af} \left( 1 - \frac {i j} {2\omega_{af}^2} \right)$$
$$w = \pm \omega_{af} + i \left( \gamma_{af} \mp \frac { j } {2\omega_{af}} \right)$$
$$ L_x = A \exp( iwt ) = A \exp \left ( \left ( -\gamma_{af} \pm \frac { j } {2\omega_{af}} \right) t \right) \times \exp \left ( \pm i \omega_{af} t \right ) $$
FINALY, when
$$ -\gamma_{af} \pm \frac { j } {2\omega_{af}} < 0$$.
we should get the stable situation.
But how to gather from here parameters I need to have a saddle point. People, help me please.
Hello there! Welcome to the forum and thanks for your post. I would be happy to help you with your questions.
For the first question, it seems like you are trying to find a relation between Lz and Lx, Ly. In this case, you can use the Pythagorean theorem to find the magnitude of Lz in terms of Lx and Ly. So, Lz = sqrt(Lx^2 + Ly^2). This way, you can replace Lz with Lx and Ly in your potential energy equation.
For the second question, it seems like you are trying to find the values of current and other parameters for your system to reach a saddle point. This is a bit more complicated and would require more information about your system and its equations of motion. It would be helpful if you could provide more context and information about your system.
1. What is a saddle point?
A saddle point is a point on a surface or in a function where the gradient is zero in one direction and has both positive and negative values in the other directions, making it a local minimum in one direction and a local maximum in the other direction.
2. What is a parameter for a saddle point?
A parameter for a saddle point is a variable or value that affects the shape or position of the saddle point in a function or surface. It can be used to control the steepness or direction of the gradient at the saddle point.
3. How is a parameter for a saddle point determined?
A parameter for a saddle point is typically determined through mathematical calculations and analysis of the function or surface. It can also be adjusted and experimented with to see its effect on the saddle point.
4. What is the significance of a saddle point in scientific research?
Saddle points have various applications in scientific research, particularly in fields such as mathematics, physics, and engineering. They can be used to optimize processes, identify critical points, and understand the behavior of complex systems.
5. Can a saddle point have multiple parameters?
Yes, a saddle point can have multiple parameters that influence its shape and position. These parameters can interact with each other to create a complex and dynamic saddle point, making it a valuable tool for studying and analyzing complex systems.
