Parameterizing Circle of Radius 3 Around (3,4)
In summary, to find a parameterization for the circle of radius 3 about the point (3,4), use the fact that sin^2 t + cos^2 t = 1 for all t and the equation (x-3)^2 + (y-4)^2 = 9. This will result in a circle with a center at (3,4) and a radius of 3.
Somefantastik
230
Find parameterizations for the circle of radius 3 about the point (3,4)
The circle of radius 3 about the origin looks like cos2t + sin2t = 3
But I can't figure out how to parameterize it around (3,4), any advice?
If you have a circle around the origin, and you want to move it so that it's a circle around the point (3,4) what vector do you have to add to your circle? Think about it in terms of transformations on the plane. Hint: You want the center of the circle around the origin to move to the center of the circle around (3,4)
the circle will be (x-3)2+(y-4)2 = 9, but how do I parameterize that?
Use the fact that [itex]sin^2 t+ cos^2 t= 1[/itex] for all t.
1. What does it mean to "parameterize" a circle?
Parameterizing a circle means to express the coordinates of points on the circle in terms of one or more parameters, such as the angle or distance from the center. This allows for a more convenient and flexible way to describe the circle's points.
2. What is the radius of the circle being parameterized?
The radius of the circle is 3 units. This means that the distance from the center of the circle to any point on the circle is 3 units.
3. What are the coordinates of the center of the circle being parameterized?
The center of the circle has coordinates (3,4). This means that the center of the circle is located 3 units to the right and 4 units up from the origin (0,0) on the coordinate plane.
4. How do you determine the coordinates of a point on the circle using the parameterization?
To find the coordinates of a point on the circle, you can use the parametric equations x = 3 + 3cosθ and y = 4 + 3sinθ, where θ is the angle from the positive x-axis to the point on the circle. Simply plug in different values for θ to find the corresponding coordinates of different points on the circle.
5. Why is it useful to parameterize a circle?
Parameterizing a circle allows for a more efficient and versatile way to describe the points on the circle. It also allows for easier calculations and manipulations, as well as the ability to easily plot points on the circle using different values for the parameter.
