Parametric Equations: Values of a, b & k for Circles A, B & C
  • Thread starter ada0713
  • Tags
    Parametric
Let's see, the values of a, b, and k for each circle can be determined by looking at the equations of the circles. For circle A, both a and b are zero because the circle is at the origin, and k is 5 because the radius is 5. For circle B, a is zero because the circle has not moved horizontally, but b is 5 because the circle has moved up by 5 units. The value of k remains at 5 since the radius is still 5. Finally, for circle C, the radius can be calculated to be 2√10, and since the circle has moved right by 10 and down by 10, a is 10 and b is -10
ada0713
45
Each of the three circles A, B and C of the figure below can be parameterized by equations of the form
x = a + k cos t, y = b + k sin t, 0 ≤ t ≤ 2.
What can you say about the values of a, b and k for each of these circles?
(figure attached below)
A: a and b are both zero because the circle is at the origin, k is 5 b/c the radius is 5
B: Since the circle moved up by 5, b is 5 and a is zero, k is agian 5 since the radius is 5
C: The circles's radius is 2[tex]\sqrt{10}[/tex] and it moved right and down by 10.
Thus, a is 10 and b is -10, and k is 2[tex]\sqrt{10}[/tex]
Above is how i came up with the answer but I'm not 100% sure.
Did I do it right, or is somthing wrong?
Well since the picture is pending approval, I would suggest to put the equation into Cartesian form and check the radius,centres and etc
1. What are parametric equations?
Parametric equations are a way of representing mathematical equations using parameters or variables. They are often used to describe the motion or behavior of objects in space, and can be expressed in terms of x and y coordinates.
2. How do you find the values of a, b, and k for a circle using parametric equations?
In order to find the values of a, b, and k for a circle using parametric equations, you first need to determine the center point of the circle (a,b) and the radius (k). The equation will be in the form of x = a + k cos(t) and y = b + k sin(t), where t is the parameter or variable.
3. Can parametric equations be used to represent other shapes besides circles?
Yes, parametric equations can be used to represent a variety of shapes such as ellipses, parabolas, and hyperbolas. The equations will vary depending on the shape being represented, but they will always involve parameters or variables.
4. How can parametric equations be useful in scientific research?
Parametric equations can be useful in scientific research because they allow for the representation of complex and dynamic systems, such as the motion of planets or the behavior of particles. They also allow for the visualization and analysis of these systems, making it easier to understand and make predictions.
5. What is the relationship between parametric equations and Cartesian equations?
Parametric equations and Cartesian equations are two different ways of representing mathematical equations. Parametric equations involve parameters or variables, while Cartesian equations use x and y coordinates. They can often be converted into each other, but parametric equations are more useful for representing dynamic systems and Cartesian equations are more useful for graphing and solving equations.
