What is the locus of R for PQ as a focal chord?
  • Thread starter Mentallic
  • Tags
    Parametric
In summary: if you can't find a pattern after a while, it might be worth looking into other options such as calculus or vector calculus.
Mentallic
3,802
95
The points [tex]P(2ap, ap^{2})[/tex] and [tex]Q(2aq, aq^{2})[/tex] lie on the parabola [tex]x^{2} = 4ay[/tex].
The equation of the normal to the parabola at P is [tex]x + py = 2ap + ap^{3}[/tex] and
the equation of the normal at Q is [tex]x + qy = 2aq + aq^{3}[/tex]. These normals intersect at R. Find the locus of R if PQ is a focal chord.
equation of line:[tex]\frac{y-y_{1}}{x-x_{1}}=\frac{y_{2}-y_{1}}{x_{2}-x_{1}}[/tex]
[tex]\frac{dy}{dx}=p=q[/tex], p & q are parameters on the parabola [tex]x^{2}=4ay[/tex]
focal chord (chord passing through focus [0,a]) is given by: [tex]y=\frac{1}{2}(p+q)x-apq[/tex]
if focal chord, pq=-1
The coordinates of R is [tex] ( –apq[p + q] , a[p^{2}+pq+q^{2}+2] ) [/tex] and since PQ is a focal chord, pq=-1, therefore this simplifies to [tex] ( -a[p+q] , a[p^{2}+q^{2}+1] ) [/tex]
From here I am completely stumped on what I need to do. I'm even unsure if the coordinates of R is necessary in this question.
Any ideas of suggestions for how I can begin to approach this question?
… what would Euclid have done?
Hi Mentallic! :smile:
Are you allowed to use ancient Greek geometry?
Draw the figure nice and large, and draw an extra couple of lines parallel to the axis of the parabola, and work out the angles (and remember why it's called the focus! :wink:)
...I honestly have no idea.
We have never used Euclidean geometry as a class. The only locus we have done so far is using the ideas that a curve is a certain distance from a point or line.
e.g. the locus of the curve that is always 4 units from the origin. By using the distance formula: [tex]\sqrt{(x_{2}-x_{1})^{2}+(y_{2}-y_{1})^{2}=4[/tex] simplified to [tex]x^{2}+y^{2}}=4[/tex]
or for e.g.2 the locus of the curve that is always equal distance between (-2,2) and (2,-2) by using the distance formula and simplifying, becomes [tex]y=x[/tex].
I don't see a possible way of applying this idea to find the locus of R. However, since pq=-1, this means that the gradients of the normal coming from P and the normal from Q are perpendicular to each other. Maybe I can find the locus by finding the curve which satisfies the two normals to the parabola that are perpendicular to each other?
Yes, that's the important point … that the two normals are perpendicular …
you could also have proved this by using the fact that lines PP' and QQ' parallel to the y-axis hit the parabola and are "focussed" onto the focus … so each normal bisects the angle between QPP' and PQQ' … so the angle between the normals is half of QPP' + PQQ', which is 180º. :smile:
Mentallic said:
The coordinates of R is … [tex] ( -a[p+q] , a[p^{2}+q^{2}+1] ) [/tex]
Ok, back to reality :biggrin: … so the locus has x = a(p+q), y = a(p2 + 1 + q2).
You need an equation relating x and y.
Hint: what is x2? :wink:
I am very bad at geometry (even worse than my locus skills :yuck:) so I don't even know what the P' and Q' points are.
Using this big hint :smile:, it seems I need to manipulate the x and y coordinates to become equal.
So,
[tex]y=a(p^{2}+q^{2}+1)[/tex]
[tex]x=-a(p+q)[/tex]
[tex]x^{2}=a^{2}(p^{2}+2pq+q^{2})[/tex]
[tex]\frac{x^{2}}{a}=a(p^{2}+q^{2}+1)+a(2pq-1)[/tex]
[tex]\frac{x^{2}}{a}-a(2pq-1)=y[/tex]
but pq=-1
Therefore, the locus is ~
[tex]y=\frac{x^{2}}{a}+3a[/tex]
I tested the locus and it is correct. Thanks for showing me another method to find loci, tiny-tim. If it weren't for the fact that I knew the locus would be parabolic and being given the hint you gave me, I probably wouldn't have noticed that I needed to find x2 to take that step closer to make it equal to y. Is the best solution just to keep my mind open and hope I realize the similarities, or are there little things to look out for when relating the x and y terms?
P' and Q' are any points on the same "vertical" line as P and Q, respectively, so that PP' and QQ' are parallel to the axis of the parabola.
All lines parallel to the axis are reflected onto the focus … that's why reflecting telescopes have parabolic mirrors … see http://en.wikipedia.org/wiki/Parabolic_reflector
Yes … basically, it's just looking for a pattern …
though in this case you might have got there more quickly if you'd realized the importance of pq = -1 as soon as you found it! :wink:
Ahh yes, we have used and proven these ideas for car headlights and face mirrors.
Oh it wasn't hard once I knew I had to find x2. The rearranging I am ok with, knowing that I need to square/cube/root I am not so alright with. Something I have to teach myself.
1. What is a parametric parabolic locus?
A parametric parabolic locus is a mathematical curve that represents all possible points on a parabola that can be generated by varying one or more parameters.
2. How is a parametric parabolic locus different from a regular parabola?
A regular parabola is defined by a fixed equation, while a parametric parabolic locus is defined by a set of equations that include one or more parameters which can be varied to produce different parabolas.
3. What are the applications of parametric parabolic loci?
Parametric parabolic loci have various applications in fields such as physics, engineering, and computer graphics. They are used to model projectile motion, design curved structures, and create visual effects in video games and animations.
4. How do you plot a parametric parabolic locus?
To plot a parametric parabolic locus, you first need to choose values for the parameters in the equations. Then, substitute these values into the equations and plot the resulting points on a graph. By connecting these points, you can visualize the parametric parabolic locus.
5. Can a parametric parabolic locus have multiple branches?
Yes, depending on the values of the parameters, a parametric parabolic locus can have multiple branches. These branches represent different parabolas that can be generated by varying the parameters.
