Homework Help: Parellel platers help
  1. Jul 20, 2009 #1
    Parellel platers help :(
    An electron with a velocity of 3.00 3 106 m/s [horizontally]
    passes through two horizontal parallel plates. The magnitude of the electric field between the
    plates is 120 N/C. The plates are 4.0 cm across. Edge
    effects in the field are negligible.
    (a) Calculate the vertical deflection of the electron.
    (b) Calculate the vertical component of the final velocity.
    (c) Calculate the angle at which the electron emerges
    Diagram: http://img50.imageshack.us/img50/6418/problemo.jpg [Broken]
    Formulas: http://img339.imageshack.us/img339/186/formulae.jpg [Broken]
    Please feel free to use your own formulas as well.
  3. Jul 20, 2009 #2
    Re: Parellel platers help :(
    Well....your own thoughts? What have you worked out?
  4. Jul 20, 2009 #3
    ive tried to comprehend this but i am failing how do i find vertical deflection because d is already given
  5. Jul 20, 2009 #4
    What do you mean by d? Can you see that there will be a force causing the electron to be deflected? (Think attraction/repulsion)
  6. Jul 20, 2009 #5
    even if i calclate fe it is ont the distance of deflection..
  7. Jul 20, 2009 #6
    How would you find a distance from the force? Hint: For how long is the force acting on the electron?
  8. Jul 20, 2009 #7
    and when it says the plates are 4.0 cm across does it mean each plate or total plates
  9. Jul 20, 2009 #8
    F=qE
    F=1.6x10^-19 C x 120 N/C
    F=1.92x10^-17 N
  10. Jul 20, 2009 #9
    can someone please help..
  11. Jul 20, 2009 #10
    Good, you have your force. I'm sure what the question meant is that the length of the plates is 4cm, such that the horizontal distance travelled by electron under the influence of the E field is 4cm.
    Now then, how would you find a distance from the force? Hint: For how long is the force acting on the electron?
  12. Jul 20, 2009 #11
    update:
    i have found the accelaration using fnet =ma
    since it is an electon mass is 9.1x10^-31
    a=1.92x10^-17 N / 9.1x10^-31kg
    a=2.1x10^13m/s2
    BUT isnt this impossible ebacause it cant accelarate more than the speed of light
  13. Jul 21, 2009 #12
    Acceleration and speed cannot be compared like that. You simply can't travel faster than light. You can accelerate however quickly you want (as long as you have the force to do it)
    You're on the right track.
