Parking my toothbrush loaded
  1. Jul 18, 2011 #1
    Instead of loading just before brushing should I load the toothbrush just after brushing & let it sit coated with toothpaste so to= 1-kill germs? 2-lose the potency of the toothpaste to the airwash unless i cover with a plastic casing & 3- whatever I didnt think of..........thanx
  3. Jul 18, 2011 #2
    berkeman
    Staff: Mentor
    If pre-loading it and letting it set for a while were the best way to do it, that would be listed as directions on the toothpaste tube, right? Just do it the regular way, and remember to floss daily. :biggrin:
  4. Jul 19, 2011 #3
    Maybe wrong, same company that makes the paste also makes the brush which supposedly needs periodic replacement due to germs.
  5. Jul 19, 2011 #4
    Alright, I might sound stupid, but what exactly is 'parking' a brush or 'loading' a brush?
  6. Jul 19, 2011 #5
    The brush is rinsed after use & then toothpaste is loaded on the brush so that it sits with toothpaste coating the bristles until the next brushing. Will the toothpaste kill the germs in the brush in this scenario?
  7. Jul 19, 2011 #6
    Well it depends on the toothpaste. Most toothpastes, as far as I know, do not have any specific disinfecting properties. A quick google search however tells me about Triclosan, which is used in some toothpastes as an antibacterial agent. If your toothpaste also uses triclosan, it might do the job. Although I don't think its a good idea doing something not mentioned in the instructions.
  8. Jul 19, 2011 #7
    berkeman
    Staff: Mentor
    A simpler solution would just be to stir the toothbrush in a small container of antiseptic mouthwash before loading it and using it.
  9. Jul 20, 2011 #8
    bobze
    You could rinse the tooth brush with 3% hydrogen peroxide. Then rinse with water.
    To be honest, desiccation is a great antimicrobial (ever notice the difference between the smell of a kitchen towel that has been kept wet vs one that was allowed to dry?).
    Toothbrushes aren't made to be permanent. So letting it dry after use should be plenty good for keeping the microbial flora down between replacements. Make sure you set it in some kind of holder or rest it with the brush part off the counter where air can circulate around the whole brush and dry it quickly.
  10. Jul 21, 2011 #9
    Here’s some useful information from The Journal of the American
    Dental Association (JADA) Volume 138:
    I should mention that if you have a tooth implant be extremely careful and gentle
    when brushing that tooth. It's also important to floss before you brush your teeth and gums. :biggrin:
