Partial Derivatives
  • Thread starter Firepanda
Firepanda
430
http://img132.imageshack.us/img132/5736/wathh1.jpg [Broken]
I think to find dz/dx (d = delta) first of all is by
dz/dx = (dz/du)(du/dx) + (dz/dv)(dv/dx)
But how do I find dz/du and dz/dv for this?
I only have 1 example that resembles this and it had z defined as a function as z = u^v, but here I don't have that, so how can I find it?
Thanks
Answers and Replies
rocomath
1,755
find dz/du * du/dx - take the derivative of u with respects to x
Firepanda
430
Sorry I don't understand, I'm trying to find dz/du first then dz/dx.
If I take the derivative of u with respect to x and hold y constant, then i get the partial derivative of du/dx. Don't I?
DavidWhitbeck
351
I don't think you mean delta. I think that you're writing the chain rule and meant to write partial derivatives and the d's are [tex]\partial[/tex] right?
I'll give you an example:
[tex]
z = uv, u=\cos (x+y), v=\sin (x+y)
[/tex]
then clearly [tex]z=\frac{1}{2}\sin2(x+y) \Rightarrow \frac{\partial z}{\partial x} = \cos2(x+y)[/tex]
But now let's use your formula and see if we get the same thing:
[tex]\frac{\partial z}{\partial u}=v=\sin(x+y),\frac{\partial u}{\partial x}=-\sin(x+y)[/tex]
[tex]\frac{\partial z}{\partial v}=u=\cos(x+y),\frac{\partial v}{\partial x}=\cos(x+y)[/tex]
So that
[tex]\frac{\partial z}{\partial x}=\frac{\partial z}{\partial u}\frac{\partial u}{\partial x}+\frac{\partial z}{\partial v}\frac{\partial v}{\partial y} \Rightarrow[/tex]
[tex]\frac{\partial z}{\partial x}=-\sin(x+y)\sin(x+y)+\cos(x+y)\cos(x+y)[/tex]
[tex]\frac{\partial z}{\partial x}=\cos2(x+y)[/tex]
And hey it's the same thing! So in that example all the derivatives are partial derivatives, and you keep the other variables constant when you evaluate them.
Firepanda
430
Ah sorry ye I thought the curly d was a delta :P
Firepanda
430
Thanks for your reply, so am I right in assuming dz/du = v and dz/dv = u?
I didn't know that, thanks.
DavidWhitbeck
351
Not in general, just in that example. For instance if you have [tex]z=u^2v^3[/tex] then [tex]\frac{\partial z}{\partial u}=2uv^3[/tex] and [tex]\frac{\partial z}{\partial v}=3uv^2[/tex].
Firepanda
430
ok well in my question
I plan on finding dz/du and dz/dv, but how do I go about this?
I don't have a z = .. like you are using in your examples unless I am misunderstanding the notation in the question.
I then plan on spending a while figuring out where to go from there :)
Edit: It says z = f(x,y) but I'm not sure what this means exactly.
Firepanda
430
:/ I just found more examples in a textbook, they all have f(x,y) equal to something, here I do not, is it a mistake with the question?
Its only worth 4 marks and it's taking me forever to do.
Hootenanny
Staff Emeritus
I'm assuming that your function f is complex valued and therefore may be written,
[tex]z = f(x,y) = u + i v = x+ay + i\left(x-ay\right)[/tex]
Therefore,
[tex]\frac{\partial z}{\partial x} = \frac{\partial z}{\partial u}\frac{\partial u}{\partial x} + i\frac{\partial z}{\partial v}\frac{\partial v}{\partial x}[/tex]
[tex] \Rightarrow z_x = \frac{\partial}{\partial x}\left(x+ay\right) + i\frac{\partial}{\partial x}\left(x-ay\right)[/tex]
An similarly for partial derivatives with respect to y. Does that help?
Firepanda
430
Yes thankyou, I'll work on from there :)
rootX
465
I am using Glyn James, and I had like 20 these like questions! :D (almost in every single exercise related to partial ...), and also we always get this type of question on the exam:
Here's two good questions:
1)
u = xy
v = x-y
z = f(u,v)
show :
x.dz/dx - y.dz/dy = (x-y)* (dz/du)
2)(little harder)
u = x+ay
v = x+by
z = f(u,v)
show
9 (d^2f/dx^2) - 9 (d^2f/dx.dy) + 2 (d^2f/dy^2) = 0
into
d^2f / du.dv = 0
Main strategy to solve these questions: draw a tree with vars!
rootX
465
Hootenanny, your solution does not any sense to me >>
Here's how I think it should be done:
z = f(x,y)
x = u+v
y = (u-v)/a
dz/du = dz/dx . dx/du + dz/dy. dy/du
-Applying multiplication rule ..
d^2z / dv.du = d/dv (dz/dx . dx/du ) + ...
= [d^z/dx^2 . (dx/du)^2 + d^2z /dx.dy * dx/du * dy/du ]+ dz/dx * dx/ du.dv * dv/dx ...
wow, it so messy but it should go like that if not necessarily exactly like above
and you final answer may have some deltas in it
Hootenanny
Staff Emeritus
z = f(x,y)
x = u+v
y = (u-v)/a
z is usually used to denote complex variables, hence I assumed that f(x,y) was complex valued. If f is indeed complex valued then u and v simply represent the real and imaginary parts of the function and the function can be differentiated as I have shown above.
rootX
465
ook thnx.
They never told/made us think that way><
[But thinking either way shouldn't give different answer, right?]
Lyn
Therefore,
Hi i am struggling too with this same question, http://img132.imageshack.us/img132/5736/wathh1.jpg [Broken]
I have tried to follow what you have said and i get my (d's are partial derivatives) dz/dx = 2. I am unsure if this is correct because just like the problem the other person had with this question, i don't have a z=... (eg z=xy)
Suggested for: Partial Derivatives
  • Last Post
  • Last Post
  • Last Post
