How to Solve Partial Fraction Decomposition for (2x+3)/(x+1)^2
In summary, the conversation is about solving for A and B in the equation (2x+3)/(x+1)^2 = (A/(x+1)) + (B/(x+1)^2) by multiplying both sides by (x+1)^2 and understanding the correct algebraic steps to take.
Rasine
208
(2x+3)/(x+1)^2
so this is what i am thinking...but it does not make sense
=(A/x+1)+(B/(x+1)^2)
so then 2x+3=A(x+1)^2+B(x+1)
2x+3=Ax^2+A2x+A+Bx+1
so that would make...
0=A
2=2A+B
3=A+B
this solution does not make any sense becuase if A=0 then according to the second equation B=2 which is not what B would equal in the third equation.
what am i doing wrong?
Your algebra is wrong
2x+3=A*(x+1)+B is correct.
I'm not sure how you are getting the equation you are working with.
what happened to to (x+1)^2 term?
(2x+3)/(x+1)^2=(A/x+1)+(B/(x+1)^2) (*)
This is wrong. Multipying both sides of (*) by (x+1)^2 gives 2x+3=A(x+1)+B
Multiplying both sides by (x+1)^2 cancels one (x+1) from the A term and both from the B term.
so should it be 2x+3/(x+1)(x+1)=(A/x+1)+(B/x+1)
here..i just split up the (x+1)^2
this is right?
(2x+3)/(x+1)^2=A/(x+1)+B/(x+1)^2. CAREFULLY multiply each of those three terms by (x+1)^2 and report back the results.
ohhh ok...i think i understand..
so if i have (2x+3)/(x+1)^2=(A/x+1)+(B/(x+1)^2) (*)
then 2x+3=A(x+1)+B because i multiply both sides by (x+1)^2
thank you very much
1. What is partial fraction decomposition?
Partial fraction decomposition is a method used to break down a rational function into simpler fractions. It involves separating the function into smaller fractions, each of which can be integrated or manipulated more easily.
2. When is partial fraction decomposition used?
Partial fraction decomposition is commonly used in calculus and engineering to simplify complex rational expressions. It is also useful in solving integrals and differential equations.
3. How is partial fraction decomposition performed?
The decomposition process involves finding the partial fractions that make up the original rational function. This is done by equating the numerator and denominator of the original function to a sum of simpler fractions, and then solving for the coefficients of each fraction.
4. What are the types of partial fraction decomposition?
The two main types of partial fraction decomposition are proper and improper. Proper decomposition occurs when the degree of the numerator is less than that of the denominator, while improper decomposition occurs when the degree of the numerator is equal to or greater than that of the denominator.
5. What are some practical applications of partial fraction decomposition?
Partial fraction decomposition has various practical applications, such as in solving integrals, finding inverse Laplace transforms, and solving differential equations. It is also used in signal processing, control theory, and other areas of mathematics and engineering.
  • Precalculus Mathematics Homework Help
