Partial fractions question
  • Thread starter phospho
Answers and Replies
Please use the template as provided next time.
You can substitute those values to find the values of [itex]A[/itex], [itex]B[/itex] and [itex]C[/itex] since we want to find those values that equal to both sides, selecting a "root" for one of the factors. We want to make both sides have same coefficients.
I'm not sure what you mean, I know this method, I'm aware of how to do it, I'm also aware of how to use other methods.
What I don't get (still after your post) is why it's allowed to use values which the question specifies is not allowed to be used (as f(x) would be undefined). Thanks for your reply, I'll be sure to use the template next time.
CAF123
88
You are writing the fraction as: $$\frac{15 - 17x}{(2+x)(1-3x)^2} = \frac{A(1-3x)^2 + B(2+x)(1-3x) + C(2-x)}{(2+x)(1-3x)^2}.$$For this to hold, the denominator must be the same on both sides. This is true by inspection. Similarly, the numerator on LHS must be the same as the numerator on the RHS. This gives: $$15 - 17x = A(1-3x)^2 + B(2+x)(1-3x) + C(2-x)$$ which has to be satisifed by all ##x##.
The condition on x not being equal to 1/3 and -2 is so that we don't end up with f(x) being undefined. The exercise above is simply to determine A,B and C. The reason we choose 1/3 and -2 is because that simplies things greatly.
Ray Vickson
Dearly Missed
10,706
1,722
Question:
http://gyazo.com/bcb6c97ba462cdf4964121a6a40b0753
Mark scheme:
http://gyazo.com/b0475e7cb980ce98fb443932c28deed2
What I don't understand is the question specifies that x is not equal to 1/3 or -2, so why are you allowed to sub them in to get the correct value for A B and C?
As CAF123 has pointed out, you have
[tex]\frac{15-17x}{(2+x)(1-3x)^2} =
\frac{A(1-3x)^2 + B(2+x)(1-3x)+C(2+x)}{(2+x)(1-3x)^2} \; x \neq -2,\, 1/3[/tex]
(although CAF123 wrote ##C(2-x)## instead of ##C(2+x)##---probably a typo).
Therefore, we have
[tex] 15-17x = A(1-3x)^2 + B(2+x)(1-3x)+C(2+x) [/tex]
for all ##x \neq -2, \, 1/3.## The reason we had to exclude -2 and 1/3 was so that we would not be dividing by zero. However, when we eliminate the denominators and just look at the numerators, we are no longer prevented from setting x to -2 or 1/3, because both numerators are perfectly well-defined at those points. In fact, we have an equation of the form
[tex] \text{polynomial 1}(x) = \text{polynomial 2}(x) [/tex] for all x different from -2 and 1/3. But, since polynomials are continuous everywhere, the equation also holds at the points -2 and 1/3. The reason that is important to note is that when x = -2 or x = 1/3, the right-hand-side is very easy to evaluate, so we can get immediately the numbers A and C. Since the two sides must be equal for all x, so are their derivatives; that allows us to get B as well.
An alternative would be to note that since the two polynomials are equal for all x, their ##x^n## coefficients must be equal. So, if you expand out the right-hand-side, you can get three equations for the three parameters A, B and C.
CAF123
88
Hmm didn't notice that, indeed a typo.
Related Threads on Partial fractions question
  • Last Post
S
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
