How to Calculate Partial Pressures of Gases at Equilibrium?
  • Thread starter pmart491
  • Tags
    Partial
In summary: ICE chart i getP H2 I2 HII 59.19atm 118.39atm 0atmC (1-0.00027) (2-0.00027) 0.00027^2E 59.18973atm 118.38973atm 0.0000000729atmso the final pressures are
pmart491
A 1L flask is filled with 1 mole of H2 and 2 moles of I2 at 448degrees Celcius. The value of the Keq for the reaction
H2 + I2 -><- 2HI at 448degrees Celcius is 50.5. What are the partial pressures of H2, I2, and HI in the flask at Equilibrium?
All reactants and products are gases. Answer is to be in atm.
PV=nRT
Pressure of:
H2 I2 HI
I
C
E
First, the initial equilibrium of HI is 0 because it doesn't exist yet.
I used PV=nRT to find pressure of H2 and I2
H2) P= 1mole x .0821 x 721K
------------------------- = 59.19atm
1L
I2) P= 2mole x .0821 x 721K
---------------------- = 118.39atm
1L
I need help trying to find what exactly happens after the system reaches equilibrium and how to find the final pressures. Thought: could the pressure of H2 be the same before and after equilibrium because the temperature remains the same? Same for I2?
I'm way past my bedtime so I'll check much much later but leaving the message here.
H2 + I2 -><- 2HI is an important equation.
You're thinking along the right track, there has to be some changes happening to the system to reach equilibrium.
Thought: could the pressure of H2 be the same before and after equilibrium because the temperature remains the same? Same for I2? No definitely not. I'll explain why down there. Read on.
You see, initially flask has 1 mole of H2, 2 mole of I2 and there is no HI at the start, just because the gases are assumed to be in there first by theory (i.e. not reacted yet). Of course the forward reaction of the equilibrium will happen; Moles of H2 and I2 will decrease and HI will be formed.
By Keq, I kind of found out that it means equilibrium constant, we call it Kp over here.
You should have some kind of equation on the Keq, try look it up, this is my simplified version:
Kp = [Partial Pressure of Reactant(s)]^power of reactant coefficient / [Partial Pressure of Product]^power of product coefficient
Try it out!
You've found the initial pressures. Find what the change is for each gas when it goes toward equilibrium, and then find what the equilibrium pressures are. It will consist of a variable.
Ok, so I went with Snazzy on this one. for the C in my ICE chart i have the change in Hydrogen as 0 because the moles of hydrogen did not change. I have the change in Iodine, I2, as -x because the number of I2 moles decreased from 2 to 1. Finally I have the change in HI as +2x because it started as 0 moles and increased to 2 moles.
I took this and plugged it in
50.5= Pressure HI
Pressure H2 x Pressure of I2
50.5= 2x
59.19 x (118.39-x)
50.5= 2x
7007.5 - 59.19x
353878.75 - 292989.095x = 2x
353878.75 = 2991.5x
x= 118.29
P H2 I2 HI
I 59.19 118.39 0
C 0 -x +2x
E 59.19 0.10 236.58
Hold on, mate. You don't know how many moles exactly will be at equilibrium for each gas. You only know that the change for I2 AND H2 is -x, and the change for HI is +2x.
Using that you can figure out what X is.
just so i can understand it, how come H2 is -x AND I2 is -x?
Both H2 and I2 start with one mole each. They both have 1 has their coefficient (1H2 + 1I2 -> 2HI).
Both of them will react with each other to produce HI. Thus, an amount of H2 mixes with an equal amount of I2 to produce HI. You don't know how much H2 and I2 react with each other, that's why you leave it as "-X".
so,
50.5=
2x
(59.19-x)(118.39-x) ?
I end up with
50.5=
2x
x^2 + 177.58x - 7007.5
What am I doing wrong?
You're not doing anything wrong. Solve the quadratic that ensues. You're actually missing a squared term for the pressure of HI since the equation gives 2 moles HI for every mole of H2 and I2.
The question said the flask started out with 1 mole of H2 and 2 moles of I2. So the final should be (1-x) mole of H2 and 2 moles of (2-x) mole of I2 if I'm not wrong. From your steps I think you're doing it fine.
Only that you need to have that [2H]² somewhere as Snazzy says. It's a matter of the power of coefficient, for example if you have α HI instead you will be using [HI]^α...since the equation gives α moles HT for every mole of H2 and I2.
oh so its x^2 and not 2x, thanks
Is it x^2? Or is it (2x)^2?
HI=x^2 H2=(1-x) and I2=(2-x)...I just have to plug in the numbers now and see what i get.
Why is it x^2 if the change is 2x for HI?
this is the ICE chart i have so far
P H2 I2 HI
C (1-x) (2-x) x^2
E 59.19(1-x) 118.39(2-x) x^2
x^2
59.19(1-x) times 118.39(2-x)when i do that i get x=square root of 707757.5 - 1061636.25x + 353878.75x^2
What is partial pressure?
Partial pressure is a measure of the pressure exerted by a specific gas in a mixture of gases. It is calculated by multiplying the total pressure of the mixture by the mole fraction of the gas.
What is an ICE chart?
An ICE chart is a tool used in chemistry to solve equilibrium problems. It stands for "Initial, Change, Equilibrium" and helps to visualize the changes in concentration of reactants and products in a chemical reaction at equilibrium.
How do you calculate partial pressure using an ICE chart?
To calculate partial pressure using an ICE chart, first write out the balanced chemical equation and determine the initial concentrations of all reactants and products. Then, use the ICE chart to determine the changes in concentration at equilibrium. Finally, use the equilibrium concentrations to calculate the partial pressure of each gas using the ideal gas law.
What is the relationship between partial pressure and mole fraction?
The relationship between partial pressure and mole fraction is direct. The partial pressure of a gas is proportional to its mole fraction in a mixture of gases. This means that as the mole fraction of a gas increases, its partial pressure also increases.
How does a change in temperature affect partial pressure?
A change in temperature can affect partial pressure by altering the volume and/or number of moles of a gas in a mixture. According to the ideal gas law, an increase in temperature will result in an increase in pressure if the volume and number of moles are held constant. However, if the volume is allowed to change, the pressure and partial pressure may also change.
  • Biology and Chemistry Homework Help
