Partial second order differential proof
In summary: I hope that helps!In summary, to prove (d^2u/dx^2) + (d^2u/dy^2) = e^-2s[(d^2u/ds^2) + (d^2u/dt^2), you would need to evaluate both sides and show that they are equal. To find du/dx, you would use the chain rule to take the derivative of u(s,t) with respect to s, while treating t as a constant. And to find the double derivatives on the RHS, you would first find the first partial derivative and then take the derivative of that result with respect to the variable you are interested in.
ProPatto16
326
if u=f(x,y) where x=e^s*cost and y=e^s*sint show that
(d2u/dx2)+(d2u/dy2) = e-2s[(d2u/ds2)+(d2u/dt2)
chain rule relevant here for du/ds and du/dt is
du/ds=du/dx*dx/s+du/dy*dy/ds and replace s with t for du/dt
for starters, I am fairly certain this proof can be shown by evaluating both sides and getting them equal. however, just a couple of questions about how to evaluate.
- for du/dx, i take derivitive of u with respect to x, so does that mean i take the derivitive of the function escost deriving variables s and t?
- for the double derivitives on the RHS that i need the chain rule for. to take the second partial derivitive do i just take du/ds of the solution to du/ds?
hope you get what i mean :/
Hello! Yes, you are correct that the proof can be shown by evaluating both sides and getting them equal. To answer your questions:
- Yes, to find du/dx, you would take the derivative of u with respect to x. This means you would take the derivative of the function u(s,t) with respect to s, while treating t as a constant. So you would use the chain rule to take the derivative of e^s*cost with respect to s, while treating t as a constant.
- For the double derivatives on the RHS, you are correct that you would need to use the chain rule. To take the second partial derivative, you would first find the first partial derivative (using the chain rule if needed) and then take the derivative of that result with respect to the variable you are interested in. So for (d^2u/ds^2), you would first find (du/ds) and then take the derivative of that result with respect to s.
FAQ: Partial second order differential proof
What is a partial second order differential proof?
A partial second order differential proof is a mathematical technique used to demonstrate the existence and uniqueness of a solution to a partial second order differential equation. It involves manipulating the equation and applying various theorems to show that a solution exists and is unique.
How is a partial second order differential proof different from a regular differential proof?
A regular differential proof deals with ordinary differential equations, while a partial second order differential proof deals with partial differential equations. The main difference is that partial differential equations involve multiple independent variables, while ordinary differential equations only involve one independent variable.
What are some common techniques used in a partial second order differential proof?
Some common techniques used in a partial second order differential proof include separation of variables, variation of parameters, and the method of characteristics. These techniques involve manipulating the equation and using known solutions to simplify the problem and find a solution.
When is a partial second order differential proof used?
A partial second order differential proof is typically used in physics, engineering, and other fields that involve systems with multiple variables. It is also used in areas such as fluid dynamics and quantum mechanics to model complex systems and understand their behavior.
What are some challenges in conducting a partial second order differential proof?
Some challenges in conducting a partial second order differential proof include dealing with complex equations, and ensuring that all assumptions and conditions are met in order to apply the necessary theorems. It also requires a strong understanding of mathematical concepts and techniques to successfully solve the problem.
