What creates a partial vacuum when a fan is in motion?
In summary, when a fan begins spinning, a partial vacuum is created. This reduced pressure is due to the intake side surfaces of the fan blade receding away from the air. This creates a void left behind by the fan blade which is filled in by air accelerating towards the fan blade. Once the air crosses the fan, there's a jump in pressure but not much change in speed. The increased pressure causes the air to continue to accelerate.
Sarcina
My understanding is that when a fan begins spinning, a partial vacuum is created. Physically, what creates this partial vacuum? Does the motion of the blades create a void in which there are fewer air molecules than in the ambient air and thus the pressure is lower than the ambient pressure?
Essentially, yes. The blades of the fan physically push molecules of air out of the way, leaving a partial vacuum behind until more air can move into replace them.
Thank you. So a spinning fan creates regions where there are less air molecules than ambient air as well as regions where there are more air molecules than ambient air; I guess this will change the density of the macroscopic air particles near the fan? Does this mean that to determine the velocity field for the macroscopic air particles near a spinning fan, you would need to solve the momentum equation for air particles with a variable density field?
The reduced pressure on the intake side of a fan is due to the intake side surfaces of the fan blade receding away from the air. What would be a void left behind by the fan blade is filled in by air accelerating towards the fan blade, but since the air has momentum, it takes a force to produce the acceleration, and the force is due to a pressure gradient where pressure decreases as the air approaches the intake side of a fan. Once the air crosses the fan. there's a jump in pressure, but not much change in speed. The increased pressure causes the air to continue to accelerate, and after the jump in pressure, the pressure decreases with distance from the output side of the fan. An approximation for the speed of the air as it crosses the fan blades is about 1/2 of the air's "exit" speed, which is the speed of the air as it's pressure returns to ambient.
Here is a link to a Nasa article about propeller's showing a similar effect. Note that the decreasing cross section of the affected air in that article is simplified, ignoring the effects of vicosity at the outer edges of the idealized air flow.
http://www.grc.nasa.gov/WWW/K-12/airplane/propanl.html
Thank you very much.
What is a partial vacuum due to a fan?
A partial vacuum due to a fan refers to a decrease in air pressure in a specific area caused by the movement of the fan blades. This creates a difference in pressure between the area surrounding the fan and the area it is blowing air towards.
What causes a partial vacuum when a fan is turned on?
When a fan is turned on, the blades begin to rotate and push air in a specific direction. This movement creates a decrease in air pressure in the area surrounding the fan, leading to a partial vacuum. The faster the fan blades spin, the greater the decrease in air pressure will be.
How does a partial vacuum affect air circulation?
A partial vacuum can greatly affect air circulation in a room or space. As the fan blows air in a specific direction, it creates a decrease in air pressure, causing air from the surrounding area to flow towards the fan. This circulation of air can help cool down a room or distribute air more evenly in a space.
What are the benefits of a partial vacuum created by a fan?
A partial vacuum created by a fan can have several benefits. It can help cool down a room or space by circulating air, which can be especially beneficial in hot and stuffy environments. It can also help improve air quality by removing stagnant air and bringing in fresh air from outside.
Is a partial vacuum due to a fan safe?
In general, a partial vacuum due to a fan is safe. However, it is important to use fans properly and follow safety precautions. For example, it is important to keep hair and loose clothing away from the fan blades to avoid injury. Additionally, it is important to regularly clean and maintain fans to prevent dust and debris from being blown into the air.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanical Engineering
  • Classical Physics
  • Classical Physics
