Homework Help: Particle along a spiral
  1. Sep 8, 2007 #1
    A particle moves outward along a spiral. Its trajectory is given by r=Aθ, where A is a constant. A=1/π m/rad. θ increases in time according to θ=αt^2/2, where α is a constant.
    Show that the radial acceleration is zero when θ=1/√2 rad. At what angles do the radial and tangential accelerations have equal magnitude?
    2. Relevant equations
    [tex]\frac{d\mathbf{r}}{dt} = \dot r\hat{\mathbf{r}} + r\dot\theta\hat{\boldsymbol\theta}[/tex]
    [tex]\frac{d^2\mathbf{r}}{dt^2} = (\ddot r - r\dot\theta^2)\hat{\mathbf{r}} + (r\ddot\theta + 2\dot r \dot\theta)\hat{\boldsymbol\theta}[/tex]
    3. The attempt at a solution
    I tried plugging things into the second equation. However, I don't know what t and α are, which is why I am stuck. I also tried substitution, but that didn't really get me anywhere either.
  3. Sep 8, 2007 #2
    learningphysics
    What are the values of a and A?
  4. Sep 8, 2007 #3
    a is supposed to be alpha, an unknown constant. A is equal to 1/(pi) m/rad.
  5. Sep 9, 2007 #4
    learningphysics
    The angular acceleration is: [tex]\frac{d^2R}{dt^2} - R(\frac{d\theta}{dt})^2[/tex]. substitute your values for R and [tex]\theta[/tex] into this equation and simplify as much as you can.
    Finally substitute in the value for theta 1/sqrt(2).
  6. Sep 9, 2007 #5
    Is angular acceleration the same as radial acceleration? Also, what is the equation for tangential acceleration? I just changed my original comment. The relevant equations are
  7. Sep 9, 2007 #6
    learningphysics
    Oops, I meant to write radial acceleration... yeah, that formula I posted is radial acceleration.
    tangential acceleration is: 2*dr/dt*w+r*d(w)/dt, where w = dtheta/dt... I looked this up here: http://aemes.mae.ufl.edu/~uhk/DYNAMICS.html [Broken] because I couldn't remember it.
  8. Sep 9, 2007 #7
    What is this part of the equation: [tex]\((r\ddot\theta + 2\dot r \dot\theta)\hat{\boldsymbol\theta}[/tex]?
  9. Sep 9, 2007 #8
    learningphysics
    That's tangential acceleration.
    This is radial acceleration:
    [tex](\ddot r - r\dot\theta^2)\hat{\mathbf{r}}[/tex]
  10. Sep 9, 2007 #9
    Thanks for the help. I think I figured it out.
  11. Sep 9, 2007 #10
    learningphysics
    Cool. no prob.
Loading...
