Proving a Uniform Energy Distribution of B in Decay A -> B + C
In summary: If I remember correctly, the constant in the equation is just the average energy per particle over all possible values of θ'. In other words, it's the average energy per particle over all possible directions the particles could go.
ryanwilk
57
Consider the decay A -> B + C (where A is not at rest). In the rest frame of A, B is emitted in a random direction (all directions have equal probability) and I need to show that in the lab frame, the energy distribution of B is uniform.
(We assume that B has negligible mass)
(Let c=1)
So I started by writing down the 4-momenta of A and B in the rest frame of A (choosing the momentum of B to be along the x axis):
PA' = (mA,0,0,0)
PB' = (EB',EB',0,0)
In the lab frame:
PA = (EA,(EA2-mA2)1/2,0,0)
PB = (EB,EB,0,0)
Lorentz boosting along the x-axis, I can determine the maximum and minimum energy that B can have:
[tex]
E_B^{\mathrm{min,max}} = \frac{E_A}{2} \bigg(1-\frac{m_C^2}{m_A^2}\bigg) \bigg(1 \pm \sqrt{1-\frac{m_A^2}{E_A^2}}\bigg)
[/tex]
using:
[tex]
\gamma = \frac{E_A}{m_A}\>,\gamma \beta = \frac{p_A}{m_A},\>E_A' = \frac{m_A^2-m_C^2}{2m_A}
[/tex]
I could also Lorentz boost in all other directions to get expressions for the energy. But I have no idea how to show that each of these energies in equally probable?
Any help would be appreciated.
Thanks!
Try calculating EA as a function of θ and show that the dE/dΩ is a constant.
Ok, so using 3D spherical polars, I get [tex]E_B(\theta') = \frac{E_A}{2} \bigg(1-\frac{m_C^2}{m_A^2}\bigg) \bigg(1 + \sqrt{1-\frac{m_A^2}{E_A^2}}\>\mathrm{cos}(\theta ') \bigg)[/tex]
(I defined it so that there is max. energy at θ'=0 and min. at θ'=π)
Then dΩ = sin(θ')dθ'dφ' and so since EB is independent of φ', dE/dΩ is a constant?
Not quite. Nothing depends on φ', so you can integrate that out and deal only with θ', so you have dΩ' = 2π sin θ' dθ' where θ' goes from 0 to π. It's convenient to change variables to cos θ' so you have dΩ' = d(cos θ') where cos θ' runs from -1 to 1. (The minus sign goes into switching the order of the limits.) When you say that a decay is isotropic, that means that the distribution N is flat as a function of cos θ'. What you want to show is that dN/dEB is constant, using the fact that[tex]\frac{dN}{dE_B} = \frac{dN}{d(\cos \theta')} \frac{d(\cos\theta')}{dE_B}[/tex](which is simply an application of the chain rule).
To show that the energy distribution of B is uniform in the lab frame, we can use the principle of relativity. This principle states that the laws of physics are the same in all inertial frames of reference. In this case, the lab frame and the rest frame of A are both inertial frames, and the energy distribution of B should be the same in both frames.
Therefore, if we can show that the energy distribution of B is uniform in the rest frame of A, then it must also be uniform in the lab frame. In the rest frame of A, B is emitted in a random direction with equal probability. This means that the energy of B can take on any value with equal probability, resulting in a uniform energy distribution.
When we Lorentz boost to the lab frame, we are essentially rotating the rest frame of A. However, this rotation does not affect the energy distribution of B. Since the energy distribution is uniform in the rest frame of A, it remains uniform in the lab frame. Therefore, the energy distribution of B is uniform in the lab frame, as desired.
In conclusion, the principle of relativity and the fact that B is emitted in a random direction with equal probability in the rest frame of A, guarantees a uniform energy distribution of B in the lab frame.
1. How do you prove a uniform energy distribution in decay?
To prove a uniform energy distribution in decay, you can perform statistical analyses on a large number of decay events. This involves measuring the energy of the particles produced in each decay and plotting a histogram to show the distribution of energies. If the energy distribution is uniform, the histogram will show a roughly flat line.
2. What is the significance of a uniform energy distribution in decay?
A uniform energy distribution in decay is significant because it indicates that the decay process is consistent and follows the laws of conservation of energy. It also suggests that the decay is a random process, and there are no preferential energy states for the particles produced.
3. What factors can affect the energy distribution in decay?
The energy distribution in decay can be affected by various factors, such as the initial energy of the decaying particle, the masses of the particles produced, and any external forces acting on the particles during the decay process. Additionally, the decay may not always be completely uniform due to statistical fluctuations.
4. How do you ensure a uniform energy distribution in decay experiments?
To ensure a uniform energy distribution in decay experiments, it is crucial to have a large sample size and to repeat the experiment multiple times. This will help to minimize statistical fluctuations and provide a more accurate representation of the energy distribution. Additionally, using high-quality detectors and controlling external factors can also help to improve the uniformity of the energy distribution.
5. Can a non-uniform energy distribution in decay be explained by any other factors?
Yes, a non-uniform energy distribution in decay can also be explained by other factors such as experimental error, detector efficiency, or contamination of the sample. It is essential to carefully analyze the experimental setup and data to identify any possible sources of non-uniformity and address them accordingly.
