Homework Help: Particle in a box question
  1. Nov 22, 2007 #1
    Hey all!
    A particle in a box of side L has wavefunction [tex]\psi[/tex](x) = Asin([Pi*x/L) for the ground state.
    a) Determine the value of A for a properly normalised wavefunction
    b) Determine the probability that x>0.75L
    2. Relevant equations
    3. The attempt at a solution
    Ok so I started off by normalising the wavefunction
    [tex]\int[/tex][tex]\psi[/tex]*[tex]\psi[/tex]dx with the limits of L and 0
    = A[tex]^{2}[/tex][tex]\int[/tex]sin[tex]^{2}[/tex](Pi*x/L)dx which would equal 1.
    Integrating...
    ∫ sin^{2} pi x/L) dx
    ∫[1 - cos(2pi x/L)]/2 dx
    ∫ dx - 1/2(L/2pi) ∫ cos(2pi x/L) (2pi/L)dx
    x/2 - (L/4 pi) sin(2pi x/L)
    applying limits 0 and L
    [L/2 - 0] - (L/4pi)[sin(2pi L/L) - 0
    L/2 - L/4 pi (0)
    L/2.
    Ok so I need a value though. So because it is in the ground state, the value of L would be [tex]\pi[/tex] I think, or is that incorrect?
    So then I had:
    A[tex]^{2}[/tex]*Pi/2 = 1
    A = 1/(\sqrt{Pi/2})
    A = 0.798
    Is this correct?
    For the second part, b)
    I'm totally confused, should I do the same as I did in part a), and integrate, but put in the limits of L and 0.75L?
  3. Nov 22, 2007 #2
    nrqed
    Do not use any value for L. Just leave it as L. It's ok to have your wavefunction containing L. In the second part, yes, integrate from 0.75 L to L. You will find out that all L dependence will cancel out in your result, leaving you with an actual number.
  4. Nov 22, 2007 #3
    I got:
    Let y = pix/L. So the limit becomes pi and 3pi/4
    ∫sin^2(y) dy
    = 0.5∫(1-cos2y) dy
    = 0.5(y - 0.5sin2y), y from 3pi/4 to pi
    =0.5(pi/4-0.5)
    1 = A^2*0.5(pi/4-0.5)
    I'm not sure if I did that right though...
    And how do I go from this to finding the probability that x>0.75L I'm a bit confused...
Loading...
