CAF123
- 88
A particle of mass m moves under the influence of a central force $$\underline{F(r)} = -mk\left[\frac{3}{r^2} - 2\frac{a}{r^3}\right] \hat{r}$$
The particle is projected from point A, at a distance a from the centre of force O, in a direction perpendicular to OA, its projection velocity is half of the velocity required for a circular orbit of radius a.
i) The radial equation of motion is $$\ddot{r} - \frac{9}{4} \frac{ka}{r^3} = -\frac{3k}{r^2}$$
Define ##u(\theta) = 1/r(t)##. Show that the above equation reduces to the linear form ##u''(\theta) + 9u(\theta) = 12/a.##
ii) Solve the equation in i) and obtain $$r = \frac{3a}{4 - cos(3 \theta)}$$ as the orbit.
i)By the chain rule, ##\dot{r} = -\frac{u'}{u^2} \dot{\theta} ## and $$\ddot{r} = -\left[\frac{u^2 u'' - 2u (u')^2}{u^4}\right] \dot{\theta}^2 + \frac{u'}{u^2} \ddot{\theta}$$ I seem to have theta dot and double dot terms that are not part of the expression I need to show. Did I do the differentiation right? If so, how do I reexpress the theta dot terms?
ii)Solving the second order linear ODE gives $$u(\theta) = A \cos(3 \theta) + B \sin (\theta) + 4/3a$$. For r, I then get $$\frac{3a}{3aA \cos(3\theta) + 3aB \sin (3 \theta) + 4}$$ I can then let aA = C, aB = D and I then thought about putting the two trig terms together into a single trig function. But I can't do this, because the final expression is solely in cos(3θ) with no phase angle. Also, they have a negative somewhere. The only way I see right now of getting a single trig term is to do as I said above but this will give a phase. (which is not what the question wants)
Many thanks.
