Particle Motion 2: Floating, Flying & Moving Freely in Space
In summary, floating in space refers to the experience of zero-gravity due to being far away from any planet or massive object. Flying is the process of movement through an atmosphere or in space. Mass is an intrinsic property of matter and motion in space is influenced by gravity. Most objects in the solar system have orbital trajectories perpendicular to the rotational axis of the body they orbit. There is no difference in satellite movement based on the plane it is in, but the concept may not apply to all objects in space.
karawan
What is the meaning of floatin and flying and moveing freely in space?
Astronomy news on Phys.org
Floating in space is the experience of zero-gravity where the mass of any object that is far away from any planet or massive object tend to zero and it becomes relatively massless where no force pull him down or toward any center of any other massive. object
Well, flying is the act or process of flight.
Flight is the process by which an object moves either through an atmosphere (especially the air), or movement beyond (as in the case of spaceflight), by generating lift, propulsive thrust or aerostatically using buoyancy, or by simple ballistic movement.
(Per wikipedia on Flight)
Mass is an intrinsic property of matter and unaffected by the presence [or absence] of other nearby masses. Motion in space is difficult to quantify, it is strictly relational. Virtually all motion in space is influenced by gravity. Most things are either in a fixed orbit or follow a trajectory dictated by prior gravitational influence. Nothing much really 'floats' in space save perhaps near Lagrange points. Nothing 'flies' in space - there is no atmosphere. Just ablut everything moves freely in space - there is no resistance to speak of.
yes chronos you are right what I meant by massless is weightless sorry .
okey . what is the difference when a satellite moves in the same plane which planets takes from one planet to another and a higher plane . this question has no sense , you may think , but think a bout the moon and the Earth and the sun and the light .
It only makes no sense because i cannot understand you. Could you try asking that again?
1. What is particle motion and why is it important to study?
Particle motion is the movement of small, individual particles through space. It is important to study because it helps us understand the behavior and properties of different types of particles, such as atoms, molecules, and subatomic particles. It also has practical applications in various fields, such as physics, chemistry, and engineering.
2. How do particles float in space without gravity?
Particles floating in space without gravity are influenced by other forces, such as electromagnetic forces and radiation pressure. These forces can counteract the effects of gravity and allow particles to move freely in space.
3. What is the difference between flying and floating particles in space?
Flying particles in space are those that are actively propelled or propelled by external forces, such as rockets or thrusters. Floating particles, on the other hand, are those that are not actively propelled, but are instead influenced by other forces, such as electromagnetic forces or radiation pressure.
4. Can particles in space move freely without any external forces acting on them?
Yes, particles in space can move freely without any external forces acting on them. This is known as inertia, which is the tendency of objects to continue moving in a straight line at a constant speed unless acted upon by an external force. In the vacuum of space, particles can continue moving freely without any external forces due to the absence of friction.
5. How does particle motion in space impact space exploration and research?
The study and understanding of particle motion in space is crucial for space exploration and research. It allows scientists to better understand the behavior and properties of particles in various environments, such as microgravity or high radiation. This knowledge can be applied to develop technologies and materials for space travel and to conduct experiments and observations in space.
  • Astronomy and Astrophysics
  • Classical Physics
  • Quantum Physics
