Solving an Annoying Equation with Trigonometry and Constants
  • Thread starter latentcorpse
Cso we have-sech(theta) = (mgh/A)^(0.5) t + Cand sosech(theta) = 1 - (mgh/A)^(0.5) t + Cbut sech(theta) = 1/x, so1/x = 1 - (mgh/A)^(0.5) t + Cand, since x = cos(theta), we havesec(theta) = 1 + (mgh/A)^(0.5) t + Cand, since sec(theta) = 1 + sech(theta), we havesec(theta) = 1 + sech((mgh/A)^(0.
latentcorpse
1,444
(dx/dt)^2 = (Mgh/A)*(2x-1)*(1-x)^2
where x=cos (theta)
and M,g,h and A are all constants
the solution is
sec(theta) = 1 + sech(sqrt(Mght/A))
if u can do it then could u please list your full answer cos i can get quite far into it and then the sech thing just confuses me
i think it involves using the weierstrass elliptic p function
HELP?!
the solution is
Hi latentcorpse! :smile:
Since they give you the answer :wink::
Hint: substitute y = 1/x - 1, and you get … ? :smile:
i forgot to mention that x = cos (theta)...my bad
also i can't get your substitution to work mainly because i don't see how that helps with the sech - i have little experience with sech so you might need to explain a bit more deeply how your getting that answer to work.
cheers guys
also i missed out the t.
ignor that first post.
here we go:
the solution is
sec(theta) = 1 + sech((sqrt(Mght/A))t)
where x = cos theta
cheers guys
Substitute y = 1/x - 1, and show us what you get.
That'll give you something which you can conveniently take the square-root of.
Just try it! :smile:
ok, if i try y=1/x - 1, then x=1/(y+1) and dy = -x^(-2) dx so dx = a x^(2) dy
this means dx/dt = sqrt(Mgh/A) (2x-1)^(0.5) (1-x)
becomes
- [(y+1)^(-2) dy]/[(((2/y+1)-1)^(0.5))(1-(1/y+1))] = (mgh/A)^(0.5) t
which gives me the argument of the sech term on the right side but i can't get the rest out!
(have a square-root: √ :smile:)
latentcorpse said:
[(y+1)^(-2) dy]/[(√((2/y+1)-1))(1-(1/y+1))] = √(mgh/A) t
Yes, but why have you stopped there? :confused:
What is (2/y+1)-1?
And what is 1-(1/y+1)? :smile:
well if y=1/x - 1 then
x = 1/(y+1)
and so y+1 = 1/x
then
(2/(y+1))-1 = 2x-1 = 2*cos(theta) - 1
and 1 - 1/(y+1) = 1 - x = 1 - cos(theta)
and then cos(theta)=1/(y+1), we have -sin(theta) d(theta) = -(y+1)^(-2) dy, giving
-[sin(theta) d(theta)]/[((2cos(theta)-1)^(0.5))(1-cos(theta)] = (Mgh/A)^(0.5) t
but how does this help us to integrate? i still can't see how the LHS works?
x = 1/(y+1)
and so y+1 = 1/x
then
Forget theta … it isn't in the question, and it isn't really in the answer (sectheta is just 1/x).
And forget x … the whole point of substituting y for x is to get away from x!
In terms of y:
(2/y+1)-1 = … ?
And 1-(1/y+1) = … ? :smile:
ok well i can't see any way of rearranging them other than factorising y+1
so that
(2/(y+1)-1)^(0.5) = (y+1)^(0.5)[1-y]^(0.5)
and,
1-1/(y+1)=(y+1)[(y+1)y]
and then substituting in and collecting these(y+1) terms with that one already on the numerator we get
-dy/[(1-y)^(0.5) (y+1)^(0.5) y]
now what?
also i see that sec(theta) is just 1/x but i think the reason I am finding this so hard is because I am looking so hard for where the sech term is going to come out
latentcorpse said:
… and then substituting in and collecting these(y+1) terms with that one already on the numerator we get
now what?
(hmm … what happened to that √ I gave you? :confused:)
Now write that as -dy/y√(1- y2). :smile:
Then make the obvious substitution. :smile:
ok
my bad about the root sign and damn i just realized i forgot to copy it again
so the obvious substitution would be some trigonometric function because of that
(1-y^2)^(0.5) term
now by y=1/x - 1 i get y=sec(theta) - 1 but that mucks things up
so i tried just y = cos(theta)
giving dy=-sin(theta) dtheta
then our LHS rearranges to
[sin(theta) dtheta]/[cos(theta) sin(theta)]
which is just the integral of sec(theta) dtheta
and the integral of sec is ln( sec(theta) + tan(theta) ) and surely i want something with a sech^(-1) in it so that i can get my sech(sqrt(Mgh/A)t) term on the RHS.
Yes, when you have a √(1 - y2), the usual substitution is either sin or cos, because sin2 + cos2 = 1.
But you can also use either sech or tanh, because sech2 + tanh2 = 1 also.
As you say, using cos gives you ln (sec + tan), which is really awkward.
So try sech intead of cos, and see what you get! :biggrin:
ok
well if y = sech(theta), dy = -sech(theta) tanh(theta) dtheta
and 1-y^2 = [tanh(theta)]^2 and so the denominator is sech(theta) tanh(theta)
then -dy/[y(1-y^2)^(0.5)] becomes
[sech(theta) tanh(theta) dtheta]/[sech(theta) tanh(theta)] but then everything cancels and we just have the integral of dtheta do we not?
latentcorpse said:
ok
Yes! :biggrin:
And the integral of dtheta is … ? :smile:
yeah but the integral of dtheta is theta
and that's equal to my right hand side of sqrt(Mgh/A) t
but if u look back to my first post that's not the solution i was aiming for
we're trying to get
sec(theta) = 1 + sech(sqrt(Mgh/A)t)
actually might be able to do a part without you! yay!
is this because if we take sech of both sides
but then sech(theta) = y = sec(theta) -1 and so it all rearranges
fantastic!
cheers for all your help m8!
legend!
we're trying to get
D'oh! :smile:
That's a different theta! :biggrin:
Try it with phi instead of theta … :wink:
EDIT: ah … you beat me to it … well done! :smile:
Hi there!
Here's my solution:
[tex](\frac{dx}{dt})^2=\frac{mgh}{A}(2x-1)(1-x)^2[/tex]
[tex]\frac{dx}{dt}=\sqrt{\frac{mgh}{A}(2x-1)(1-x)^2}[/tex]
[tex]\frac{dx}{dt}=(1-x)\sqrt{\frac{mgh}{A}(2x-1)}[/tex]
[tex]\frac{mgh}{A}=K[/tex]
[tex]\frac{dx}{(1-x)\sqrt{K(2x-1)}}=dt[/tex]
[tex]\displaystyle{\frac{1}{\sqrt{K}}\int\frac{dx}{(1-x)\sqrt{2x-1}}}=\displaystyle{\int}dt[/tex]
[tex]2x-1=z^2 <=> x=\frac{z^2+1}{2}[/tex]
[tex]2dx=2zdz <=> dx=zdz[/tex]
[tex]\displaystyle{\int}\frac{1}{(1-x)\sqrt{2x-1}} dx}=\displaystyle{\int}\frac{z}{(1-\frac{z^2+1}{2})z} dz=\displaystyle{2\int}\frac{1}{1-z^2} dz=\displaystyle{2\int}(\frac{1}{2(1-z)}-\frac{1}{2(1+z)}) dz=\displaystyle{\int}(\frac{1}{(1-z)}-\frac{1}{(1+z)}) dz=\ln{\frac{1-z}{1+z}[/tex]
[tex]z=\sqrt{2x-1}[/tex]
[tex]\ln{\frac{1-z}{1+z}=\ln{\frac{\sqrt{2x-2}}{\sqrt{2x}}=\ln\sqrt{\frac{2-2x}{2x}}=\displaystyle{\frac{1}{2}}\ln{2\frac{1-x}{x}}=\displaystyle{\frac{1}{2}}\ln{\frac{1-x}{x}}+c[/tex]
[tex]\frac{1}{2\sqrt{K}}\ln{\frac{1-x}{x}}+c=t[/tex]
[tex]\ln{\frac{1-x}{x}}=2\sqrt{K}(t-c)[/tex]
[tex]\displaystyle{\frac{1-x}{x}}=e^{2\sqrt{K}(t-c)}[/tex]
[tex]1-x=xe^{2\sqrt{K}(t-c)}[/tex]
[tex]x(1+e^{2\sqrt{K}(t-c)})=1[/tex]
[tex]x=\displaystyle{\frac{1}{1+e^{2\sqrt{K}(t-c)}}[/tex]
[tex]\cos{\theta}=\displaystyle{\frac{1}{1+e^{2\sqrt{K}(t-c)}}[/tex]
[tex]\sec{\theta}=1+e^{2\sqrt{K}(t-c)}[/tex]
[tex]\sec{\theta}=1+e^{2\sqrt{\frac{mgh}{A}}(t-c)}[/tex]
which is very similar to the solution given :) - s.o. has to prove the last term
If s.o. finds a mistake in it, I would be glad to see where it is :)
What is the definition of "particularly annoying"?
"Particularly annoying" refers to something that is especially bothersome or irritating.
What are some examples of things that can be particularly annoying?
Some examples of things that can be particularly annoying include loud noises, slow internet connections, and repetitive tasks.
Why do people find things that are particularly annoying so bothersome?
People find things that are particularly annoying bothersome because they can be disruptive to daily activities and cause frustration or stress.
How can one deal with something that is particularly annoying?
One way to deal with something that is particularly annoying is to try to find a solution or workaround. Another way is to find ways to relax and reduce stress, such as deep breathing or taking a break.
Can something that is particularly annoying have any positive effects?
While something that is particularly annoying can be frustrating, it can also serve as a motivator to find solutions and improve the situation. It can also help build resilience and patience in dealing with challenging situations.
  • Differential Equations
