Calculating Force/Mass Using Pascal's Principle for Baby-Lifting Car
In summary: The car will be lifted 1 ft. after the baby's piston is completely compressed. In summary, a 22 pound baby sitting atop a 1 ft^2 piston that is connected to a 10 ft^2 platform via sealed, water filled pipes can lift a 2,200 pound car.
predentalgirl1
67
(a) If a 22 pound baby sits atop a 1 ft^2 piston that is connected to a 10 ft^2 platform via sealed, water filled pipes, how heavy and massive of a car can the baby's weight lift (answer in pounds, Newtons, and Kilograms)?
(b) If the baby's initial height on the piston is 10 ft, how high will the car be raised after the baby's piston is completely compressed?
3. a)
F1/A1=F2/A2 or
P1 = P2
Let baby sitting on 1ft^2 platform be P1 --> 22lbs/144in^2 = .153 lbs/in^2
Let car on platform be P2 -->
weight of car/14400in^2 =P2
--> weight of car = 14400in^2 X .153 lbs/in^2 = 2,203.2 lbs.
Powerful baby.
I assumed pounds in this problem meant pounds force rather than pounds mass. 1 pound force = 4.45 N so 22 lb = 97.9 N, and the mass that would give 97.9 N is 97.9N/9.8m/s^2 = 9.99 kg
(b)
If the baby\'s piston is completely compressed, the volume of water the baby\'s piston held will now be in the other piston - the one holding the car on a platform. First you figure out what volume of water would be in the baby's piston before it was compressed. So you had a cylinder with a cross sectional area of 1 ft^2 and a height of 10 ft, so that is a volume of 1ft^2X10ft = 10ft^3.
That\'s the volume that will be transferred to the other cylinder, but since that cylinder has a larger cross sectional area, the height the water will rise will be less than 10 ft.
Volume = Area of base times height
10ft^3 = 10ft^2 X H -->
H = 1 ft. The car will be raised 1 ft.
Are my answers/solutions correct?? Or did I make a mistake? Please help me...thanks in advance!
There is a big difference between (10ft)^2 and 10ft^2. And you seem to be using one in a) and another in b). Also in a) you are asked for the stats (in lbs, N and kg) for the car, not the baby. Further, there is no need to convert to in^2. Overall, this is kind of confusing. Can we focus on one problem. Like for example, in a) you say the baby can lift something 100 times it's mass, in b) you say the distance displaced by the car is 1/10 that of the baby. Those two are definitely in conflict.
is this correct??
a>. Applying pascals law , pressure transmitted will be equal through sealed fluid at two pistons
we get f/a} ={F/A,
f,F are force exerted at smaller & larger cross section & a ,A are cross sectional areas resp.
force exerted at larger cross section F =( f/a) x A
F= (22 x g) x 10 = 220 x g wt pounds = 220 pounds(mass) car will be lifted.
In Kg : 220 x0.46=101.2 kg , In Newton 101.2 x9.8 = 991.76N
Yes. The ratio of the two forces is equal to the ratio of the areas. Likewise, the ratio of the displacements. If you let v=volume, then volume=AH where H is the change in height. So V=v means AH=ah so H=ah/A.
That makes more sense.
I didn\'t need to convert to inches. I think I wanted to deal with psi, but it isn\'t really necessary since you don\'t require the conversion. And I don’t know why I converted the baby’s weight to Newtons and kilograms instead of the car’s! But this time I converted the car’s weight.
a) So P1=P2 --> 22lb/1ft^2 = x/10ft^2 --> x = 2,200 lbs.
and 2,200 lbs. X 4.45 N/lb = 9790N
9790N/9.8 m/s^2 = 998.98 kg
1. What is Pascal's Principle?
Pascal's Principle, also known as the principle of transmission of fluid-pressure, states that when there is an increase in pressure at any point in a confined fluid, there is an equal increase at every other point in the container.
2. How does Pascal's Principle relate to calculating force/mass for baby-lifting cars?
Pascal's Principle can be used to calculate the force needed to lift a baby in a car by using the formula F = P x A, where F is the force, P is the pressure, and A is the area. By increasing the pressure in the car's hydraulic system, the force needed to lift the baby is also increased.
3. What is the role of surface area in calculating force using Pascal's Principle?
The surface area plays a crucial role in calculating force using Pascal's Principle because the pressure is directly proportional to the surface area. The larger the surface area, the greater the force that can be generated using the same amount of pressure.
4. What are some practical applications of Pascal's Principle in everyday life?
Pascal's Principle is used in many everyday objects such as hydraulic car jacks, hydraulic lifts, and hydraulic brakes. It is also used in medical devices such as blood pressure monitors and syringes.
5. How do you ensure safety when using Pascal's Principle for baby-lifting cars?
To ensure safety when using Pascal's Principle for baby-lifting cars, it is important to carefully calculate the necessary force and pressure, and to regularly check and maintain the hydraulic system to prevent any malfunctions. It is also crucial to have proper training and knowledge when operating hydraulic systems.
15K
  • Mechanical Engineering
  • Classical Physics
  • General Engineering
14K
