PHP Passing form data to PHP
  1. May 10, 2007 #1
    Math Is Hard
    Staff Emeritus
    I am working on a simple example of trying to pass form data to my php program.
    I am not sure how to pass the variable that holds the data the user enters.
    Here's what I've tried. (note, it only looks right in Firefox, but that's what we're supposed to be writing it for).
    http://www.pic.ucla.edu/~jctaylor/callhello3.htm [Broken]
    and this is my php script:
    #!/usr/local/bin/php
    <?php
    echo $_GET['hello'];
    Thanks for any help!
    (oh, and I am using jquery libraries - forgot to mention)
  3. May 10, 2007 #2
    chroot
    Staff Emeritus
    $_GET referes to the URL query string. A URL's query string is anything that comes after a '?' character.
    For example,
    http://www.pic.ucla.edu/~jctaylor/callhello3.htm?hello=goodbye [Broken]
    - Warren
  4. May 10, 2007 #3
    the problem is this line where you're trying to pass the contents of the keywords text field to your script
    Code (Text):
    $("//div#content").load("hello.php?hello=keywords");
    The way it's written, you're telling hello.php to run with a variable called hello set to "keywords".
    try something like
    Code (Text):
    $("//div#content").load("hello.php?hello="+this.keywords);
    which would (should) append the query string with the value from the keywords element.
    Oh, and the script will break if you enter more than one word. Working around that I'll leave as an exercise for you.
  5. May 10, 2007 #4
    Math Is Hard
    Staff Emeritus
    oh, thanks!! I appreciate the help!! I'll give it a try!:cool:
  6. May 11, 2007 #5
    Math Is Hard
    Staff Emeritus
    hmmm.. still haven't got it sorted out. It says "undefined".
  7. May 11, 2007 #6
    -Job-
    Since your input object only has a name property (and no ID)
    Code (Text):
    <INPUT name=keywords>
    You can use the following to get its value:
    Code (Text):
    document.getElementsByName('keywords')[0].value
    So in your code you'd have:
    Code (Text):
    <SCRIPT type=text/javascript>
          $(document).ready(
            function(){
              $("//p#b1/a").click(
                function(){
                  $("//div#content").empty();
                  $("//div#content").load("hello.php?hello=" + document.getElementsByName('keywords')[0].value);
        </SCRIPT>
    If you give your input control an ID:
    Code (Text):
    <INPUT name=keywords id=keywords>
    Code (Text):
    document.getElementById('keywords').value;
    Or you can use jquery:
    Code (Text):
    $("input#keywords").val()
    And you'd have, after giving your control an ID:
    Code (Text):
          $(document).ready(
            function(){
                function(){
                  $("//div#content").load("hello.php?hello=" + $("input#keywords").val());
        </SCRIPT>
  8. May 11, 2007 #7
    Math Is Hard
    Staff Emeritus
    oh, OHHH My GOODNESS! It's working!!!!!!! Oh, wow - cool! per your suggestion, I gave the INPUT an ID property and used jquery to get the value.
    Thanks so much, Job!!!!:smile: :smile: :smile:
