What is the estimated path length traveled by a deuteron in a cyclotron?
In summary, the deuteron traveled a total path length of 346 meters in a cyclotron of radius 53 cm and operating frequency 12 MHz.
gmark
Estimate the total path length traveled by a deuteron in a cyclotron of radius 53 cm and operating frequency 12 MHz during the entire acceleration process. Accelerating potential between dees is 80 kV.
mass m = 3.2e-27 kg
charge q = 1.6e-19 C
radius r = 0.53 m
frequency f = 12e6 /s
potential V = 80e3 V
(1) kinetic energy KE = .5*m*v^2
Consider a charged particle of mass m, charge q, velocity v perpendicular to magnetic field B. The particle will travel in a circle of radius r with frequency f:
(2) r = (m*v)/(q*B)
(3) f = (q*B)/(2*pi*m)
(4) V = J/C
My plan is to calculate the KE the particle has on leaving the machine (r = .53m). This total KE results from N crossing of the dees. So divide the final KE by the KE per crossing to get N. The total number of revolutions is half of N. Estimate the total path length by multiplying N/2 by the outer circumference of the machine, 2*pi*r.
1. Final KE
rearrange (2) above: v = (r*q*B)/m
substitute for v in (1):
(5) KE = (m/2)*(r*q*B/m)^2
rearrange (2) B = (2*pi*m*f)/q
substitute for B in (5) and simplify: KE = 2*m*(r*pi*f)^2
Using values given above, KE = 2.67e-12 J (r = .53m).
2. KE per crossing
rearrange (4) J = V*C
Using values given (V=80e3, C=1.6e-19)
KE = 1.28e-14 J
Dividing total KE by per-crossing KE gives 208 crossings, 104 revolutions.
3. Estimated distance is 2*pi*r*104 (r=.53m) = 346 m.
Given answer is 240 m.
Hi,
Particle doesn't start at the outer rim but very close to the center
Thanks for your reply. Unfortunately I don't know how to proceed. All I can think of is silly: take the derivative of final KE (step 1 above) wrt the radius, and integrate from r=0 to r=0.53. This accomplishes nothing, of course, and results in the same wrong answer I got before.
Calculate the trajectory radius after 1, 2, 3, etc revolution (= 2, 4, 6, ... acceleration steps)
Thanks. That works. Yay for Python and brute force.
1. What is the purpose of a cyclotron?
A cyclotron is a type of particle accelerator used to accelerate charged particles, such as protons and ions, to high energies. It is commonly used in scientific research, medical treatments, and industrial applications.
2. How does a cyclotron work?
A cyclotron uses a combination of electric and magnetic fields to accelerate particles in a circular path. The particles are generated at the center of the cyclotron and are then accelerated by an electric field towards the outer edge, where they are then extracted for use.
3. What is the path length in a cyclotron?
The path length in a cyclotron is the distance traveled by the particles as they are accelerated in a circular path. This distance is determined by the size and design of the cyclotron and is typically several meters long.
4. Why is path length important in a cyclotron?
The path length in a cyclotron is important because it affects the energy and velocity of the particles being accelerated. A longer path length allows for higher energies to be achieved, while a shorter path length may limit the maximum energy that can be reached.
5. How is the path length in a cyclotron controlled?
The path length in a cyclotron is controlled by adjusting the strength of the magnetic field and the frequency of the electric field. By changing these parameters, the particles can be accelerated at a specific rate and reach a desired energy level.
