• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Pedagogical Machine
472
1. Homework Statement
A “pedagogical machine” is illustrated in the sketch (attached image). All surfaces are frictionless. What force ##F## must be applied to ##M_1## to keep ##M_3## from rising or falling?
2. Homework Equations
$$\sum_{}^{} \vec{F} = m \vec{a}$$
3. The Attempt at a Solution
I have chosen a coordinate system such that all particles have positive coordinates. My ##x##-axis points to the right and my ##y##-axis points upwards. The length of the rope remains constant, and it can be expressed as:
$$l = x_p - x_2 + \frac{\pi R}{2} + y_p - y_3$$
The pulley is located at ##(x_p,y_p)##.
Differentiating twice with respect to time and rearranging:
$$\ddot{x}_2 + \ddot{y}_3 = \ddot{x}_p$$
Since the pulley and ##M_1## are fixed:
$$\ddot{x}_2 + \ddot{y}_3 = \ddot{x}_1$$
Since ##\dot{y}_3 = 0## for all ##t##, ##\ddot{y}_3 = 0##.
In other words:
$$\ddot{x}_1 = \ddot{x}_2$$
Now, applying Newton's second law to each mass:
$$T - M_3 g = 0 ⇒ T = M_3 g$$
$$T = M_2 \ddot{x}_2$$
$$F - T = M_1 \ddot{x}_1$$
Where ##T## is the tension in the rope.
$$M_3 g = M_2 \ddot{x}_2 ⇒ \ddot{x}_2 = \frac{M_3 g}{M_2} = \ddot{x}_1$$
$$F = T + M_1 \ddot{x}_1 = M_3 g (1 + \frac{M_1}{M_2})$$
$$F = M_3 g \frac{M_1 + M_2}{M_2}$$
Which doesn't match the clue given in my book. According to my book, if all three masses are equal, then ##F = 3Mg##.
Where did I go wrong?
haruspex
Insights Author
2018 Award
31,712
4,687
How do you get your equation ##F-T=M_1\ddot x_1##? What are the forces acting on M1?
472
In the ##x##-direction, there's ##F## and ##T##.
##T## acts on the pulley, which is a part of ##M_1##.
haruspex
Insights Author
2018 Award
31,712
4,687
Yes, but you've missed a force. What makes M3 accelerate?
472
The net force caused by the difference between ##N## and ##N'## (different normal reactions)?
472
$$\vec{F}_{31} = -\vec{F}_{13}$$
The net force on ##M_3## is to the right, so the force ##M_3## exerts on ##M_1## must be to the left.
I guess I missed an additional constraint:
##\ddot{x}_1 = \ddot{x}_3## since ##x_3## and ##x_1## differ by a constant.
I got the right answer, thanks!
I have a question though, the equation only holds if ##M_3## is always in direct contact with ##M_1##, right?
I have not taken into account the fact that ##M_3## can swing left and right while deriving the first constraint equation.
haruspex
Insights Author
2018 Award
31,712
4,687
Yes, if the two do not start quite in contact then there will be a different behaviour initially, but it wouldn't last long.
Want to reply to this thread?
"Pedagogical Machine" You must log in or register to reply here.
Related Threads for: Pedagogical Machine
  • Posted
  • Posted
10K
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
