Pendulum angle problem
Ready2GoXtr
75
1) A pendulum consists of a 2 kg stone swinging on a 4 m long string
of negligible mass. The stone has a speed of 8 m/s when it passes its
lowest point. a) What is the speed of the rock when it is at an angle of
60 degrees to the vertical? b) What is the greatest angle with the vertical
that the string will make during the stone's motion?
Not really sure Just trying to do it with energy conservation..
Well I figured out that at 60 degree's the height of the stone from the ground is 2m
Thne I figured I should use E = k+mgy ...
and came up with Einitial = (1/2)(2kg)(8m/s)^2 + (2kg)(-9.8m/s^2)(4m)
Efinal = (1/2)(2kg)(v)^2 + (2kg)(-9.8m/s^2)(2m)
Where to go Next... no clue
Answers and Replies
Dick
26,263
619
"energy conservation". Set Einitial=Efinal and solve for v.
Dick
26,263
619
Be careful about the sign and stuff on your gravitational terms though. It's mgh, where h is the height above the ground and there is no minus sign on the g.
Ready2GoXtr
75
Really... can you tell me what that is derived from like ive seen deltaE = E final - E initial..
Dick
26,263
619
There's no energy going into or out of the system. So deltaE=0. Right?
Ready2GoXtr
75
Im getting v @ 60 degrees = sqrt(55.2) You?
Ready2GoXtr
75
Okay for part B im going to assume that Einitial will remain the same... But Efinal will be = 0 + (2kg)(9.8m/s^2)(4m(1-cos(theta))
Ready2GoXtr
75
Then again Im assuming I can set them equal to each other.. cause no energy is gained or lost. so That gives me 94.4 = (2kg)(9.8m/s^2)(4m(1-cos(theta))
94.4 = 19.6(4m(1-cos(theta))
94.4 = 78.4(1-cos(theta))
.204081633 = -cos(theta)
-.204081633 = cos(theta)
cos^(-1)(-.2040816330) = theta
Ready2GoXtr
75
im getting (theta) = 101.775744 degrees
101.8 Degrees
Dick
26,263
619
Sorry. No, I don't get that. Can you post details? And you didn't post part B either. So I don't know what you are working on.
Suggested for: Pendulum angle problem
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
18K
  • Last Post
  • Last Post
  • Last Post
