Homework Help: Pendulum bobs
  1. Dec 2, 2012 #1
    Conservation of energy: looking for equations to solve the following
    2. Relevant equations
    A pendulum with length l = 0.50 m and with a negligible mass. The string is attached to a fixed point A and the pendulum swings in a vertical plane.
    The pendulum has a speed v = 2.15 m s–1 at the lowest point of its swing.
    I need to work out the pendulums speed at intervals so 10,20,30,40 degrees
    3. The attempt at a solution
    I have already calculated the time period of the swing to T = 2 pi sqrt l/g, which means T= 1.59s, also the height of the swing from lowest point to end is 0.49m
    Any help would be great, thanks
  3. Dec 2, 2012 #2
    Doc Al
    Staff: Mentor
    Why not use conservation of energy.
  4. Dec 2, 2012 #3
    How would i use it to get the speeds at intervals though?
  5. Dec 2, 2012 #4
    Doc Al
    Staff: Mentor
    Figure out the height of the pendulum at each of those points.
  6. Dec 2, 2012 #5
    I've already worked out the swing heights at any given interval, its the speed in m/s i need.
    Thanks
  7. Dec 2, 2012 #6
    Doc Al
    Staff: Mentor
    How would you express conservation of mechanical energy for the pendulum?
  8. Dec 2, 2012 #7
  9. Dec 2, 2012 #8
    v=SQRT(2*KE/m).
  10. Dec 2, 2012 #9
    Doc Al
    Staff: Mentor
    OK, that how to get velocity from KE.
    What's an expression for the total energy of the pendulum?
  11. Dec 2, 2012 #10
    E = mgL[1 - cos(θ0)] ?
  12. Dec 2, 2012 #11
    Doc Al
    Staff: Mentor
    That will give you the gravitational PE, measured from the lowest point.
    What's the total energy?
  13. Dec 2, 2012 #12
    Sorry i dont know
  14. Dec 2, 2012 #13
    Doc Al
    Staff: Mentor
    Look up total mechanical energy (and conservation of energy) in your textbook.
  15. Dec 2, 2012 #14
    Tme = pe + ke
  16. Dec 2, 2012 #15
    Doc Al
    Staff: Mentor
    Good!
    That's conserved as the pendulum moves.
  17. Dec 2, 2012 #16
    Ok so now what - total mech en = pot en + kin en
    What step do i take next?
  18. Dec 2, 2012 #17
    Doc Al
    Staff: Mentor
    Energy is conserved. It remains constant:
    E1 = E2
    PE1 + KE1 = PE2 + KE2
    Let position 1 be the lowest point; position 2 being any other position you need to solve for.
  19. Dec 3, 2012 #18
    How do i get the speed from that equation though?
  20. Dec 3, 2012 #19
    Doc Al
    Staff: Mentor
    Once you have the KE at each point, then you can get the speed using KE = 1/2mv^2. (See the equation you showed in post #8.)
  21. Dec 3, 2012 #20
    But i still have no figure for Mass so i cannot calc - KE = 1/2mv^2
Loading...
