Solving Pendulum Confusion: m*a=-k*x Explained
In summary, the conversation discusses the equation ##m*a=-k*x## and its validity. The direction of the restoring force is opposite from the displacement from equilibrium, and for a pendulum with small amplitude, the equation of motion is approximately ##mass*length^2*angular acceleration=-mass*gravitational acceleration*length*angle##. The - sign comes in because the gravitational acceleration always acts against the angular displacement theta.
LLT71
73
I find it somehow confusing to imagine why m*a=-k*x is "generally valid". that minus sign bothers me. Imagine I raised a bob to some height (ex. from the left side) and then released it. from that moment till the moment where it reaches equilibrium position m*a and restoring force have same direction. from a moment where it "goes of" the equilibrium position to the moment when it reaches the same height on the right side m*a and restoring force have different direction and so on. should it be m*a=+-k*x? what I'm missing?
##ma## IS the restoring force. The direction is opposite from the displacement from equilibrium
god I feel so stupid... thanks that was straight forward!
No need to feel stupid. It looked convincing ! And: you are welcome.
Likes LLT71
for a pendulum with small amplitude: the equation of motion is approximately: mass* length^2 *angular acceleration = - mass * gravitational acceleration * length * angle.
the k does not come in. the restoring torque is - mass * gravitational acceleration * length * angle. The magnitude of the restoring force is: mass * gravitational acceleration. The - sign come in because the gravitational acceleration is always downward, and acts to close the angle theta. if the bob is on the left hand side, for example theta is less than zero and the force acts to increase theta. If the bob is on the right hand side, theta is greater than zero, and the gravitational force acts to decrease theta. the gravitational force always acts against the angular displacement theta.
Likes LLT71
1. What is the equation for solving pendulum confusion?
The equation for solving pendulum confusion is m*a=-k*x, where m is the mass of the pendulum, a is the acceleration, k is the spring constant, and x is the displacement from equilibrium.
2. How does this equation explain the motion of a pendulum?
This equation explains the motion of a pendulum by relating the mass, acceleration, and displacement to the spring constant. The mass and acceleration of the pendulum determine the force, while the displacement and spring constant determine the strength of the force. This equation helps us understand how different factors affect the pendulum's motion.
3. What is the role of mass and acceleration in this equation?
The mass and acceleration play a crucial role in this equation as they determine the force acting on the pendulum. The larger the mass, the greater the force, and the larger the acceleration, the greater the force. This force is what causes the pendulum to move back and forth.
4. How does the spring constant affect the motion of a pendulum?
The spring constant, represented by the letter k, determines the strength of the force acting on the pendulum. A higher spring constant means a stronger force, resulting in a faster and more frequent oscillation of the pendulum. A lower spring constant means a weaker force, resulting in a slower and less frequent oscillation.
5. Are there any real-life applications of this equation?
Yes, this equation is used in various fields such as physics, engineering, and even in everyday objects like clocks and amusement park rides. It helps in understanding and predicting the motion of pendulums and other systems that follow simple harmonic motion.
  • Mechanics
  • Mechanics
  • Mechanics
