What is the Solution to the Pendulum Energy Problem?
In summary, the conversation discusses the energy at a height d above a reference point, the height of a mass after half a revolution, and the distance from a peg to the mass. The solution is given as E = (1/2)mv^2 + 2mg(L-d) and the distance from the peg to the mass is L-d. There is confusion about the values of d and L, but it is clarified that d is the distance from the peg to the mass and L is the length of the string.
PhizKid
477
Mechanical conservation
It says the energy at height d = (1/2)mv^2 + 2mg(L-d)
Isn't it just mgL = mgd + (1/2)mv^2 ? Since mgd is the final potential energy, at height d above the reference point which is taken to be the lowest point.
It says that is the energy at half a revolution. So what height will the mass be above the reference point when it has gone through half a revolution? (the answer is not d).
Why isn't half a revolution d? Isn't it from the bottom of the peg to the top of the peg, which is halfway around the peg from the starting point? (If we take the vertical line down from the peg to the floor to be the reference point)
Let us take the lowest level of the bob (of mass m) as our reference level when any height of the bob is measured.
What is the height of the bob of mass m after half of a revolution?
As Bruce W said, this the height asked for in my previous post is not d.
Do you mean the height is the distance from the position of the mass when it is at its lowest, to when it is at its highest? If that is what you mean, then yes I agree. But this distance is not d. Think about taking an actual piece of string, and what will the distance be? Maybe first think about what is the distance from the peg to the mass (hint: look at the diagram).
Then it's d/2
Try to find the radius with which the mass performs the half circle round the peg.
PhizKid said:
Then it's d/2
You are not meant to assume that L is twice the length of d. (Although it might look like that from the picture).
The radius is d/2, then. Since the diameter is d. I don't understand the length we are trying to find. Half a revolution means 180 degrees, right? So we are looking for the subtended distance or the angular displacement?
In the picture, what is the distance from the peg to the mass?
From the picture, it looks like peg to the mass is d/2. From the mass on the bottom to the dotted lines area at where d is. And the peg looks to be in the center of that.
That's the problem. Peg to the mass is not d/2
Pivot to peg is d and the entire length of the string is L. So what is the distance from peg to the mass?
Edit: just to clarify, we are talking about the part of the picture where the mass is hanging straight down.
Ohhh. L - d then, lol
I see now...I thought the picture was saying that 'd' was marking the height from the very bottom of the picture..
haha, I see what you mean now. Yeah, that is a bit confusing. Well, hopefully now you can see where their answer comes from.
Edit: to confirm, yes peg to mass is L-d
1. What is a pendulum energy problem?
A pendulum energy problem refers to a physics problem that involves analyzing the energy of a pendulum system. This typically includes determining the potential energy, kinetic energy, and total energy of the pendulum at different points in its swing.
2. How do you calculate the potential energy of a pendulum?
The potential energy of a pendulum is calculated using the equation PE = mgh, where m is the mass of the pendulum, g is the acceleration due to gravity, and h is the height of the pendulum's center of mass above its lowest point.
3. What is the relationship between the length of a pendulum and its energy?
The length of a pendulum affects its energy by changing its period, or the time it takes to complete one full swing. A longer pendulum has a longer period and therefore has more time to transfer energy between potential and kinetic energy, resulting in a higher total energy.
4. How does friction affect a pendulum's energy?
Friction can cause a loss of energy in a pendulum system. This is because friction acts against the motion of the pendulum, converting some of its kinetic energy into heat. This results in a decrease in the total energy of the pendulum over time.
5. Can a pendulum have more kinetic energy than potential energy?
Yes, a pendulum can have more kinetic energy than potential energy at certain points in its swing. This occurs when the pendulum is at the bottom of its swing, where it has the highest velocity and therefore the most kinetic energy. As the pendulum swings back up, the kinetic energy is converted back into potential energy.
