Pendulum Motion
  • Thread starter corey2014
corey2014
A simple pendulum has a length of 4.9 m and is pulled a distance y = 0.5 m to one side and then released.
(a) What is the speed of the pendulum when it passes through the lowest point on its trajectory?
(b) What is its acceleration when it passes through the lowest point on its trajectory?
I think this is the equation I am supposed to use? omega=sqrt(2(9.8)(L(1-cos(a))) where omega is velocity max and L is length of pendulum, a is angle between Pendulum and its starting position
Not totally sure what to do with equations...
I tried solving for a and I got 1.262896 radians
then a final speed of 9.287 m/s
Answers and Replies
PeterO
2,435
62
Hopefully the question had a diagram with it, which will enable you to answer the following question: Was the 0.5 m the length of the arc along which the bob was drawn back, or is it the horizontal distance to the side, that the bob is drawn?
JHamm
391
Use the work energy theorem.
corey2014
There is no diagram but because it says y= can't I assume that its in the Y direction? And what is that theorem?
JHamm
391
I think it means the horizontal distance it is displaced, the work energy theorem says that the total change in kinetic energy of an object is equal to the sum of the work done on that object. In this case the work done by gravity in going from the highest position to the lowest is equal to the kinetic energy at the lowest (since its speed was 0 in the highest position).
technician
1,506
This is a problem about Simple Harmonic Motion (SHM)
A simple pendulum can be assumed to perform SHM.
The amplitude, A, of the motion is 0.5m.
The Time period and therefore the angular velocity can be found from the pendulum equation
T =2∏√l/g, ω=2∏/T
In SHM max velocity occurs when amplitude = 0 and is given by ωA
Acceleration when amplitude = 0 is ZERO
Max acceleration = ω^2 A and occurs when displacement = A
All of this makes the usual assumptions about a simple pendulum.... small angle etc.
Suggested for: Pendulum Motion
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
