What is the Speed and Total Mechanical Energy of a Simple Pendulum?
In summary, at the lowest point of the swing, the bob has potential energy and kinetic energy. The total energy is .34v^2 + .88137.
thatgirlyouknow
58
[SOLVED] Pendulum Speed and total ME
The length of a simple pendulum is 0.84 m and the mass of the particle (the "bob") at the end of the cable is 0.68 kg. The pendulum is pulled away from its equilibrium position by an angle of 7.8 ° and released from rest. Assume that friction can be neglected and that the resulting oscillatory motion is simple harmonic motion. (a) What is the angular frequency of the motion? (b) Using the position of the bob at its lowest point as the reference level, determine the total mechanical energy of the pendulum as it swings back and forth. (c) What is the bob's speed as it passes through the lowest point of the swing?
E = .5mv^2+.5Iw^2+mgh+.5kx^2
w = sqrt(g/L)
L-Lcos@ = max height of pendulum bob
I of pendulum = (1/3)ML^2
so w = 3.416 rad/s
The total energy:
.5(.68)(v^2) + .5(1/3 ML^2)(w^2) + mgh + .5kx^2
kx^2 is potential energy, which is 0 at the bottom of the swing
.34v^2 + (1/6)(.68*.84^2)(3.416^2) + .68*-9.8*.00777
.34v^2 + .88137
v^2 = 2.5922
v = 1.61 m/s
Plugging this in gives a total ME of 1.7627 J
The v and total E are wrong, but I'm not sure how to remedy this. Ideas, please? Thanks!
Whao, slow down there, your using way too many equations! When the plumb bob is at it's highest point, what type of energy does it have?
It has potential energy, mgh. But the question asks for total mechanical energy at the bob's LOWEST point.
Yes, but if you know that at it's highest point it only has potential energy and you know the energy is conserved, then what is the value of the total energy at the lowest point?
So I totally overanalyzed that one... oh well.
Thanks for the help!
No worries :approve:
1. What is a pendulum?
A pendulum is a weight suspended from a fixed point that can swing back and forth under the influence of gravity.
2. How is the speed of a pendulum determined?
The speed of a pendulum is determined by its length and the force of gravity acting on the weight.
3. What is the relationship between pendulum speed and total mechanical energy?
The total mechanical energy of a pendulum remains constant, meaning the sum of its kinetic and potential energy is always the same. Therefore, as the pendulum swings back and forth, its speed will vary but its total mechanical energy will remain constant.
4. How does changing the length of a pendulum affect its speed and total mechanical energy?
Changing the length of a pendulum will affect its speed and total mechanical energy. As the length of the pendulum increases, its speed will decrease and its total mechanical energy will increase. Conversely, as the length decreases, the speed will increase and the total mechanical energy will decrease.
5. Can the total mechanical energy of a pendulum be changed?
No, the total mechanical energy of a pendulum cannot be changed. It will always remain constant as long as there is no external force acting on it, such as friction or air resistance.
