Pendulum Timer question
  1. Jan 20, 2009 #1
    If I have two exact pendulum timers (like the one in the picture below) and I place a weighted object at the end of the one stick, and towards the bottom (near the base) on the other, which one will swing faster?
    http://wwwdelivery.superstock.com/WI/223/1613/PreviewComp/SuperStock_1613R-8223.jpg
    2. Relevant equations
    3. The attempt at a solution
  3. Jan 20, 2009 #2
    Nabeshin
    Any intuitive ideas as to what will happen? How do you think the concepts of physics apply to this problem? What changes when you add the weight?
  4. Jan 20, 2009 #3
    Nabe, the weight distribution is the obvious difference. I think the timer with the weight towards the base will swing faster. The reason being is because of the experiment that I conducted with my 31oz Demarini baseball bat: with one hand, I grabbed the bat around the barrel (fat part) and continued to supinate and pronate my wrist and few times. I did the same thing again, the only difference with the subsuquent test was that I grabbed the bat towards the handle (bottom) and then preformed the wrist supination and pronation. Moviing the bat was 'easier' when I was holding it by the handle as opposed to around the barrel.
    The 'end' of the bat, the barrel, has a greater amount of weight distributed at its end compared to the handle. Therefore, I conclude that the pendulum timer with the weight towards the base will move faster than the timer with the weight loaded towards the end of the stick.
    Am I right?
  5. Jan 21, 2009 #4
    Nabeshin
    Your conclusion is correct, and I like the fact that you tried an experiment to figure it out!
    However, saying "I did this with a baseball bat..." is not sufficient explanation to draw conclusions about a different system. To add a little rigor to the conclusion, think specifically about moment of inertia.
  6. Jan 21, 2009 #5
    Thanks. I have not had any Physics classes in quite some time. When in doubt, try to see if you can exprapolate abstract ideas from specific examples. :)
    Nabe, could you please elaborate a bit on how inertia relates to this specific scenario.
    Thanks in advance,
    E
  7. Jan 21, 2009 #6
    Nabeshin
    Well, like I said, the key concept here is moment of inertia. When the mass is distributed farther away from the pivot point, the moment of inertia increases (it is proportional to r^2). This is what you are seeing in your baseball bat example. The higher the moment of inertia, the harder it is to move, so, given an equal force, the slower it will move.
Similar Discussions: Pendulum Timer question
  1. Pendulum question (Replies: 1)
  2. Pendulum question (Replies: 1)
  3. Pendulum Questions (Replies: 1)
  4. Pendulum question (Replies: 14)
Loading...
