Penrose diagram of black hole with a changing event horizon
In summary: The definition of the horizon is that it's the boundary of the region from which light can't escape to infinity.I find this somewhat surprising - the black hole expands and the photon moves "outwards" - but that's probably simply a consequence of using global coordinates.Correct. The Penrose diagram is not meant to represent the local dynamics of the spacetime, but rather its global geometry. It's a useful tool for understanding certain properties of black holes, but it has its limitations as well.In summary, the Penrose diagram is a useful tool for understanding global properties of the spacetime, such as the behavior of black holes. However, it does not accurately represent the local dynamics and should not be used for that purpose. Additionally, the
Sonderval
234
Dear all,
I have a question on Penrose diagrams. Consider a collapsing star that forms a black hole with a Schwarzschild radius normalized to 1. What happens in the Penrose diagram when additional matter falls in? I suspect the diagram then has to look like this :
When the outer shell (second curved line) reaches the event horizon, the radius of the BH will increase (r>1). Is this diagram correct? If so, what would happen when a photon is emitted exactly at the moment the BH forms? This photon would then be frozen at the event horizon, but from the diagram it seems as if it could actually move outward to the greater event horizon (because it follows a 45-degree line). Or is this way of thinking incorrect and the diagram looks different?
The second question is related. Here is the diagram for an evaporating BH (from inspirehep)
Again, I am wondering what happens to a photon trapped at the event horizon when the hole shrinks? Will it be "sucked inwards" and stay at the event horizon until the BH has evaporated completely and will then emerge from the r=0-position?
Thanks for any help,
Martin
Basically what you describe, yes.
It stays at the horizon. That's the definition of the horizon.
Remember that the Penrose diagram is using coordinates that have been specially adjusted to make the horizon be that particular 45 degree up and to the right line, regardless of what happens to the hole. It can gain mass from things falling in, lose mass by evaporation, and even disappear, as your second diagram shows, and none of that changes the horizon line--because the Penrose diagram coordinates are adjusted, using the entire history of the spacetime as input, to make the horizon line look like that.
In other words, the Penrose diagram is not very helpful if you want to understand the dynamics of the spacetime--what things look like locally to a particular observer. The purpose of the Penrose diagram is to easily show certain global properties of the spacetime, which is why it has to use the entire global history of the spacetime for its construction. From a local observer's viewpoint, a Penrose diagram can't even be constructed; the observer would have to know the entire future history of the entire spacetime to know where on a Penrose diagram his particular worldline fits.
Likes Sonderval
@PeterDonis
Thanks a lot.
I assume the same is true for the case of the expanding hole.
I find this somewhat surprising - the black hole expands and the photon moves "outwards" - but that's probably simply a consequence of using global coordinates. OTOH, it shows that Penrose diagrams are really useful for eactly this kind of consideration.
Thanks again,
Martin.
Yes.
1. What is a Penrose diagram?
A Penrose diagram is a graphical representation of the spacetime geometry around a black hole. It is a 2-dimensional projection of the 4-dimensional spacetime, allowing us to visualize the behavior of light and objects near a black hole.
2. How is the event horizon represented in a Penrose diagram?
The event horizon is represented as a diagonal line on the Penrose diagram, dividing the diagram into two regions: the exterior region, where light and objects can escape from the black hole, and the interior region, where nothing can escape.
3. What does a changing event horizon mean in a Penrose diagram?
A changing event horizon in a Penrose diagram refers to the event horizon of a black hole that is growing or shrinking over time. This can happen due to the addition or loss of mass in the black hole, or due to the influence of nearby objects.
4. How does the shape of the Penrose diagram change with a changing event horizon?
The shape of the Penrose diagram can change depending on how the event horizon is changing. If the event horizon is growing, the diagram will expand outward, and if it is shrinking, the diagram will contract. The exact shape and size of the diagram will also depend on the specific properties of the black hole and its surroundings.
5. What insights can be gained from studying a Penrose diagram of a black hole with a changing event horizon?
Studying a Penrose diagram of a black hole with a changing event horizon can provide insights into the behavior of light and objects near a black hole, as well as the effects of mass and external forces on the event horizon. It can also help us understand the concept of time dilation and the warping of spacetime in the presence of a black hole.
