swatmedic05
- 42
Could someone help this is I don't get the question
{|g-g^exp|}/g*100
accepted value of g=980 cm/s^2
{|g-g^exp|}/g*100
The purpose of solving this equation is to determine the percentage difference between two values, g and g^exp, using a fixed value of g=980. This can be useful in various scientific and mathematical calculations such as error analysis and comparison of experimental and theoretical values.
To solve this equation, you can follow these steps:1. Substitute the value of g=980 into the equation.2. Calculate g^exp by raising g to the power of exp.3. Find the absolute value of the difference between g and g^exp.4. Divide the absolute value by g.5. Multiply the result by 100 to get the percentage difference.
The symbol | |, known as the absolute value symbol, indicates the distance of a number from zero on a number line. In this equation, it is used to find the absolute value of the difference between g and g^exp.
Yes, you can use any value for g in this equation. However, using a fixed value of g=980 is useful in situations where you want to compare the percentage difference between g and g^exp with a standardized value.
This equation can be applied in various real-life scenarios such as calculating the error in scientific experiments, comparing the accuracy of different measurement methods, and determining the percentage change in stock market values.
