Calculating Percentage of Uncertainty in Momentum: Tips and Tricks
  • Thread starter CollectiveRocker
  • Tags
    Uncertainty
In summary, Daniel found that when he uses the % formula: (delta p *100%)/p, he ends up with 100% as his percentage. However, the uncertainty in momentum can be larger than the momentum.
CollectiveRocker
137
How do you go about finding the percentage in the uncertainty of momentum, if you already know the momentum and delta momentum? I'm asking because both of them end up being the same; thus I'm wondering if I'm terribly wrong. Any advice?
To find the percentage change divide the change in momentum by the (starting) momentum and multiply by 100%. The change in momentum has units of momentum but the percentage change has no units so they are not the same.
The thing which I've discovered is that when I use that formula, I only end up with 100% back again. Are delta p and p supposed to be the same? For I've taken the things I know, the uncertainty in position and charge, and rearranged them in order to solve for things which I don't know.
Any ideas guys?
Can you give some more context with this question? Specifically, is it about Quantum Mechanics and Heisenberg's Uncertainty Principle, or something else?
It is about Heisenberg's Uncertainty Principle. We are given the uncertainty for the position of the 1 KeV electron, and we're asked to find the percentage of uncertainty in it's momentum. Now, I've already found the uncertainty of momentum. However, when I use that answer and solve for momentum, both mometum and the uncertainty in momentum are equal. Thus when I use the % formula: (delta p *100%)/p, I end up with 100% as my percentage. What am I doing wrong?
This is ceratinly not my area of expertise, but why do you think having the uncertainty equal to the momentum is an incorrect answer? From what I understand the uncertainty can be larger than the momentum as well.
Doesn't that mean that my percentage in my uncertainty is 100%?
Why not??As far as the calculations u made are correct,then that should be it.But i'd like to see all the numbers,though.U say the KE of the electron is 1KeV.Please give us the uncertainty in distance.
Daniel.
the uncertainty of position is .100 nm
I'm sorry to say,that,but you screwed up the numbers.Did u use the correct (nonrelativistic) formula for the momentum in terms of the KE??If so,combined with Heisenberg formula u should be getting less than 1%.
Daniel.
The formula for KE = (p^2)/2m
k = 2pi/lambda, and delta p = h/lambda
I also get less than 1% uncertainty.
with what formula
with what formula
Nope,delta p_x is given by the Heisenberg (not de Broglie) formula wrt to h and delta x
for delta p do you get 6.626 * 10^-24?
Yes.This thread is getting annoyingly long. :tongue2:
I'm sorry to keep on testing your patience. So then we solve for k using k = 2pi/lambda, because lambda = delta x, and I get 6.283 * 10^10
Pay attention.It's not difficult at all:
[tex] E=\frac{p^{2}}{2m} [/tex] From which [tex] p=\sqrt{2mE} [/tex].Plug in the numbers,and find the result.If u don't know,learn that
[tex] m=9.1\cdot 10^{-31} kg [/tex].
Express the enrgy in Joules,compute the momentum and from there,devide the number u got for [itex] \Delta p [/itex] through the number u got for "p" and express the final result in terms of procents.
Daniel.
is the answer .08?
It's ok, I've got it. Thank you for all your help and patience.
What is percentage of uncertainty?
Percentage of uncertainty is a measure of the potential error or inaccuracy in a measured quantity. It is expressed as a percentage of the measured value.
How is percentage of uncertainty calculated?
Percentage of uncertainty is calculated by dividing the absolute uncertainty by the measured value and then multiplying by 100%. The absolute uncertainty is typically the smallest division on the measuring instrument.
Why is percentage of uncertainty important in scientific measurements?
Percentage of uncertainty is important because it allows us to understand the reliability and accuracy of our measurements. It also helps us to determine the level of confidence we can have in our results and conclusions.
How does the precision of a measuring instrument affect the percentage of uncertainty?
The precision of a measuring instrument directly affects the percentage of uncertainty. A more precise instrument will have a smaller absolute uncertainty, resulting in a lower percentage of uncertainty.
Can percentage of uncertainty be reduced?
Yes, percentage of uncertainty can be reduced by using more precise measuring instruments, taking multiple measurements and calculating the average, and minimizing potential sources of error in the measurement process.
