Perfect square in 2 bases
  1. Aug 9, 2009 #1
    Does anyone know if its possible to check whether a number is a perfect square in 2 different bases ? ( I dont mean the representation of a number in 2 different bases - coz that would be a ridiculous question , what I mean is consider a no say xyz - is it possible to prove / disprove that it is a perfect square when considered in 2 bases .. i.e. lets say bases m and n ..... then the numbers would be x * m^2 + y * m + z in base m and x* n^2 + y*n + z in base n) .
  3. Aug 9, 2009 #2
    CRGreathouse
    If a sequence of digits is a square in some base it should be possible to find that base by exhaustive testing. If not, I'm not sure how to prove it -- unless perhaps it's close to a perfect power, like 101_b = b^2 + 1.
  4. Aug 10, 2009 #3
    What I am looking for is basically an algorithm ... Suppose I find one such base by exhaustive testing , now is it possible to find another base , or do I have to do exhaustive testing to find the second base too .
    Or is there some way to rule out a certain sequence of digits from being a perfect square in all possible bases , or maybe is it always possible to find a base in which a sequence of digits will be a perfect square, given that the sequence of digits satisfy some relation .
    All I am able to see is the following :
    1. that if the sequence has only 1 non zero digit :
    Here there are 2 scenarios -
    1st scenario : in case that the sequence has an even no. of digits ( when we do not consider the leading zeroes before the non zero digit of course) then u can always find a base in which the number is a perfect square ..
    eg. p000 , where p is any digit ( or even a letter representing a single digit in bases higher than 10)
    then in a base q the no. would be :
    = p * q^3
    = p*q * q^2
    Now if q = (p*any perfect square)
    , then we can clearly see the number is a perfect square in base q , i.e we have an infinite no. of bases in which the number is a perfect square
    2nd scenario : the sequence has odd no. of digits - In this case the only way for the num to be a square in any arbitrary base is if the non zero digit itself is a perfect square - this can be seen similar to above.
    2. If the digits are in a Geometric progression :
    If the no. is (k digits):
    r(k-1) r(k) ... r0
    If let us say the common ratio is r , then in a base q , the num would be :
    r0 * { (r*q)^k - 1 } / {r - 1}
    Now we require the num to be a square , so the above num should be a square,
    If now somehow we find integer solns of q by equating the above to a square , then we can find the bases ,
    If we choose a square no x^2 ,
    then we have :
    r0 * { (r*q)^k - 1 } / {r - 1} = x^2
    well I guess this just leads us to an even bigger problem to solve ....
    nyways can anyone find some relation , that may help in determining the solution ?
  5. Aug 10, 2009 #4
    400 is a perfect square in any base n
    961 is also a perfect square in any base n
  6. Aug 10, 2009 #5
    400 does not exist in any base n < 5.
    961 does not exist in any base n < 10.
  7. Aug 11, 2009 #6
    You were just a hair off. p000 is a perfect square in any base [tex]p^{2n+1}[/tex] n > 0
Loading...
