B Perfect square
According to you this theorem is correct?
Exercise 1.2 * Proof that ##\sqrt{x}## isn't a rational number if ##x## isn't a perfect square (i.e. if ##x=n^2## for some ##n∈ℕ##).
In effect, if ##x=\frac{25}{9}##, so ##x## isn't a perfect square, then ##\sqrt{x}=\sqrt{\frac{25}{9}}=\frac{5}{3}## is rational.
10,373
3,890
But for this proof to work:
x must be a member of N too
and so sqrt of x is not a rational number.
@fresh_42 can answer this better.
fresh_42
Mentor
Insights Author
2018 Award
10,069
6,798
There is nothing to add. Either restrict ##x\in \mathbb{N}## or generalize ##n \in \mathbb{Q}##.
PeroK
Insights Author
2018 Award
9,104
3,280
To put it another way.
If ##x## is a positive integer, then either ##\sqrt{x}## is a positive integer; or, ##\sqrt{x}## is irrational.
WWGD
1,726
One way of doing the proof for Rationals is to generalize the argument that ##\sqrt 2## is not Rational to ##\sqrt n##.
32,392
4,154
But here x is a perfect square (##(\frac 5 3)^2 = \frac {25} 9##, but as has already been pointed out, x is not a positive integer.
WWGD
1,726
But you need to be careful on how you define a perfect square otherwise every no negative real number is a perfect square.
32,392
4,154
Understood, but when we talk about perfect squares, the context is seldom real numbers. In this thread the context was ##x \in \mathbb N## (more specifically, from post #1, ##x = n^2## with ##n \in \mathbb N##) and the OP gave an example with ##n^2 = \frac {25} 9##.
Want to reply to this thread?
"Perfect square" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
