Perihelion shift in (very) near-circular orbits
  1. Feb 27, 2016 #1
    Jorrie
    The full power series for the Schwarzschild portion of perihelion shift is given in Mathpages as:
    where [itex]L = a(1-\epsilon^2)[/itex], [itex]a[/itex] the semi-minor axis and [itex]\epsilon[/itex] the eccentricity. This implies that as [itex]\epsilon[/itex] tends to zero, the perihelion shift tends to a non-vanishing [itex]6\pi m/a[/itex] + some much smaller higher order terms.
    If we do an angular acceleration derivation for a Schwarzschild orbit ([itex]d^2\phi/dt^2[/itex]), I have arrived at
    [tex]\frac{d^2\phi}{dt^2} = \frac{-2v_r v_\phi}{r} \frac{r-3m}{r-2m}[/tex]
    where [itex]v_r=dr/dt[/itex] and [itex]v_\phi=d\phi/dt[/itex] (geometric units: c=G=1)
    Pervect and CarlB have arrived at equivalent results in this old orbital acceleration thread.
    My question is that since [itex]d^2\phi/dt^2[/itex] goes to zero when [itex]v_r[/itex] goes to zero for the circular orbit, how is this compatible with the non-vanishing perihelion shift above?
  3. Feb 28, 2016 #2
    Orodruin
    Staff Emeritus
    2017 Award
    Why do you think there is a contradiction here? The circular orbit does not have a perihelion - all points on the orbit are at the same distance from the central object and therefore the angular velocity must be constant.
  4. Feb 28, 2016 #3
    Jorrie
    The question is then: is the power series from Mathpages giving the perihelion shift inadequate?
  5. Feb 28, 2016 #4
    Orodruin
    Staff Emeritus
    2017 Award
    No. Again I do not understand why you would think there is a contradiction here. The limiting orbit has perfectly circular shape and such an orbit has constant angular velocity. There is no black magic here. If you perturb it ever so slightly you get an orbit with a perhelion shift.
  6. Feb 28, 2016 #5
    Jorrie
    I agree, but this is not what the power series says is the limiting case. It gives an 'invisible' shift of 6 pi m/r. Which again raises my question: is the series inadequate, e.g. to describe orbits with extremely small eccentricities?
  7. Feb 28, 2016 #6
    Orodruin
    Staff Emeritus
    2017 Award
    Why would you think the series would be inadequate? There is no contradiction anywhere in your expressions. You are misinterpreting and misrepresenting the results. The answer really was in my previous post.
    Also, this is nothing different from what would occur in classical mechanics with a central potential different from the 1/r. It is just that the period of small oscillations around the circular orbit does not match with the orbital period.
  8. Feb 28, 2016 #7
    Jorrie
    OK, I think I understand what you are saying. The amplitude of radial oscillations goes to zero, but not the period. So the lowest order peri-shift approximation in the series is independent of eccentricity (for constant L), but higher orders will show an eccentricity influence.
  9. Feb 28, 2016 #8
    Orodruin
    Staff Emeritus
    2017 Award
    Talking about eccentricity influence is a bit misleading as the point is that the orbit is not an ellipse.
    It might be more instructive to view things in terms of the relative periods between radial oscillations and the orbital period. The radial oscillations will have different periods depending on the amplitude as long as the effective potential is not harmonic.
  10. Feb 28, 2016 #9
    Jorrie
    Good point, thanks. :smile:
Similar Discussions: Perihelion shift in (very) near-circular orbits
Loading...
