Homework Help: Period of a bobbing cork
  1. Jul 1, 2009 #1
    A cork floats in water. The cork is a cylinder with radius 1 cm and height 3.4 cm. The density of the cork is 0.55 g/cc. Calculate the period of oscillation if the cork is pushed down a little and released.
    2. Relevant equations
    I think I need help with the restoring force... please.
    3. The attempt at a solution
    -1st I found the mass of the cork - M=D*V =
    D = (.55g/cm3)*(1kg/1000g)*(100cm/m)3 = 550kg/m3
    V = pi*r2*h = pi*(.01m)2*.034m = 1.068E-5 m3
    M = 550kg/m3*1.068E-5m3 = 5.874E-3 kg
    -Then setting up my differential:
    Fnet = Frestore + Fgravity
    Fr = -Dh2o*Vh2o : (Density of water * volume of water displaced)
    Fg = mg
    ma = mg - Dh2o*Vh2o
    volume is dependent on y, or the height, so V = pi*r2*y
    -rearranging the equation my'' + Dh2o*pi*r2*y = mg
    divide by m --> y'' + Dh2o*pi*r2*y/m = g
    and setting y=ert
    r1=+isqrt(Dh2o*pi*r2*/m)
    r2=-isqrt(Dh2o*pi*r2*/m)
    I don't need the particular solution because we need to calculate the period, and
    y(t) = Acos{sqrt(Dh2o*pi*r2*/m)t}
    + Bsin{sqrt(Dh2o*pi*r2*/m)t}
    the period should be 2*pi/(sqrt(Dh2o*pi*r2*/m) right?
    I got .859s but this is not correct. If anyone has some advice, I would be much obliged.
  3. Jul 1, 2009 #2
    turin
    I would first suggest to redefine y so that y=0 when the cork is at equilibrium. Then, you a have a VERY popular (in physics) type of 2nd order diff. eq., from which you can directly read off the frequency. Actually, it is not really necessary to redefine y, but I think it might make the equation easier for you to recognize.
    BTW, y=e^rt is certainly not correct.
  4. Jul 1, 2009 #3
    Try phrasing the restoring force as a force of the form [tex]\vec F(y) = -C\vec y[/tex], and think about what that says about the system.
    A good way to start is to look at what the net force on the cork is at equilibrium, and what it is when you've displaced it by a height of [tex]y[/tex] into the water (Remember that the force [tex]mg[/tex] doesn't change).
    A good mental analogy to make in this case would be comparing it to a vertical spring, I assume you've already dealt with that problem, try and remember how you dealt with the effect of gravity there, it's very similar here.
