Period of Oscillations
  1. Oct 28, 2007 #1
    A solid, uniform disk of mass M and radius a may be rotated about any axis parallel to the disk axis, at variable distances from the center of the disk.
    If you use this disk as a pendulum bob, what is T(d), the period of the pendulum, if the axis is a distance d from the center of mass of the disk?
    I got the answer to be:
    T(d) =2{\pi}\sqrt{\frac{0.5a^{2}+d^{2}}{gd}}
    The period of the pendulum has an extremum (a local maximum or a local minimum) for some value of d between zero and infinity. Is it a local maximum or a local minimum?
    2. Relevant equations
    3. The attempt at a solution
    I graphed the function and saw that as d increases, the period T also increases to a maximum. However, I am not clear about the physical reason as to why this is so. Please advise.
    Thank-you!
Draft saved Draft deleted
Similar Discussions: Period of Oscillations
  1. Period of Oscillation (Replies: 3)
  2. Period of oscillation (Replies: 8)
  3. Period of oscillation (Replies: 3)
  4. Oscillation Period (Replies: 10)
Loading...
