• Support PF! Buy your school textbooks, materials and every day products Here!
Periodic motion
Identical ropes were tied to two trees, and two men, A and B, started shaking the free ends at the same instant a short while ago (Figure 1) .
Which rope has the greater tension?
Which man is shaking with the greater frequency?
T=1/f λf=v
For the first question, I would like to go for that rope B has greater tension, because the whole rope is moving.
For the second question, I went for A>B, because the wavelength is shorter in A than in B. But the answer is wrong, should I go for B>A then? Because the tension in B may be larger than A?
Answers and Replies
Dr. Courtney
Education Advisor
Insights Author
1,998
You need the relationship between tension and frequency.
the greater the tension the greater the frequency
TSny
2,761
At the time shown, how many times has person A moved the rope up and down since the start?
this information is not given in the question
TSny
2,761
Can you deduce it from the figure?
5 times?
does this mean that B has higher frequency because he moved 6 times up and down for the same time interval? thus the tension in b is also greater.
TSny
2,761
OK, roughly 5 (it's hard to tell exactly). How about B?
TSny
2,761
Sounds right to me.
The frequency is not directly related to the tension. If you put a certain tension in the rope, you can wiggle it at a high frequency or a low frequency (for the same tension). So, in that sense, the frequency is independent of the tension. Higher frequency does not necessarily imply higher (or lower) tension.
Sounds right to me.
so the tension would be equal if the rope is the same
TSny
2,761
The tension depends on how hard the person pulls horizontally on the rope.
A>B? because part of the string is undisturbed.
TSny
2,761
What do you mean when you write A>B?
tension of string A is greater than that of B
TSny
2,761
Have you learned any relationship between tension and wave speed?
the greater the tension the greater the wave speed
TSny
2,761
Yes. Try to use that to figure out which rope is under greater tension.
since wave speed equals to wave length times wave frequency. Tension of A is smaller because it has lower frequency and shorter wavelength.
TSny
2,761
OK. That's a good argument.
Another approach: Can you tell directly from the figure which wave has the greater speed? (You might have already noticed this in your first post where you said that for B "the whole rope is moving".)
So the wave speed in B is greater because it reaches the end faster.
TSny
2,761
Yes.
Related Threads for: Periodic motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
