Permissible error
  • Thread starter Malu666
How to calculate the permissible error?
A force F is applied on a square plate of size L . If the percentage error in determination of L is 2% and that in F is 4% . What will be the permissible error in pressure?
Answers and Replies
rude man
Insights Author
836
EDITed:
Depends on how you define "permissible".
First, you say a "square" sheet. Is it really square? You have to assume "I don't know" so the area could be that of a general quadrilateral. That requires the measurement of 4 sides plus two opposite angles: http://keisan.casio.com/exec/system/1322718508
Plus a 7th independent measurement is for the force F.
So, assume the error in measuring each side's length and that of each of the two angles is 2%,
if the errors are random in all 7 cases, error propagation theory says to take the square root of the sum of the squares:
error = √(6(.022) + .042) = 0.063 = 6.3%.
But there is also the "worst-case" error which you would get if all your measurements are at their respective extremes, in which case the error would be (1.02)6(1.04) - 1 = 17.1%.
Thanks for the reply. Maybe you went for a higher level of explanation. I think that the question interconnects between force , area and pressure. As pressure = force/ area , can you precisely explain about the permissible error in pressure ?
rude man
Insights Author
836
If the error in force is 4.0% and the error in area is 2.0%, the error in pressure is √(.0402 + .0202) = 4.4%.
But L is likely to mean length, not area, so then it'd be √(.0402 + .0202 + .0202) = 4.9%.
haruspex
Insights Author
7,362
We are told it is square. The two length errors are correlated?
Evo
Mentor
23,544
3,204
Just a friendly reminder, if the template isn't used or the information required in the template isn't used, such as what the member has tried themselves to solve the problem, please do not reply, please send a report.
rude man
Insights Author
836
OK. Sorry. I thought after I wrote that it was probably excessive. Will be more on guard henceforth.
r m
Evo
Mentor
23,544
3,204
r m
You're cool, we're just trying to get things more even in responses, some members get turned back while some get answered.
haruspex
Insights Author
7,362
Good point. So it's just √(.022 + .042).
No, the answer should get bigger, not smaller.
Related Threads on Permissible error
  • Last Post
  • Last Post
48K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
