Find Permutability of Matrices: Algebra Homework Help
  • Thread starter esmeco
  • Tags
    Matrices
In summary, the conversation discusses the concept of exchangeable and permutable matrices. The person is seeking help in finding the set of permutable matrices and clarifies that a matrix is permutable if all rows and columns are the same and if it is a square matrix. However, there is confusion about the definition of exchangeable and permutable.
esmeco
144
I have this question as homework from my Algebra class:
A square matrix X is called exchangeable with A if AX=XA.Determine the set of permutable matrices with
My question is,how do I find that set?I know that a matrix to be permutable all rows and columns must be the same and that a square matrix is composed by the same number of rows and columns.
Thanks in advance for the help!
You defined exchangable, not permutable, so who knows?
By exchangeable i meant permutable...
You defined what it means for X to be exchachangable *with A*, not what it means for X to be exchangable, or permutable.
1. What is the definition of permutability of matrices?
Permutability of matrices refers to the ability to rearrange the elements of a matrix without changing its overall structure or properties. In other words, if two matrices can be transformed into each other through a series of row or column swaps, they are considered to be permutable.
2. How do you determine if two matrices are permutable?
To determine if two matrices are permutable, you can use the commutative property of matrix multiplication. If the product of the two matrices remains the same regardless of the order of multiplication, then the matrices are permutable. This means that the matrices can be rearranged without changing the result of the multiplication.
3. What is the significance of finding the permutability of matrices?
Finding the permutability of matrices is important in various applications of linear algebra, such as in solving systems of linear equations, computing determinants, and calculating eigenvalues. It also helps in simplifying calculations and reducing the number of steps needed to solve certain problems.
4. Can all matrices be permuted?
No, not all matrices can be permuted. For two matrices to be permutable, they must have the same dimensions. This means that the number of rows and columns must be the same for both matrices. Additionally, the matrices must have the same number of elements in each row and column.
5. How can I find the permutability of matrices?
To find the permutability of matrices, you can use various techniques such as finding the transpose, calculating the determinant, or performing matrix operations. These methods can help determine the similarity or equivalence of two matrices, which in turn, can indicate their permutability.
