Permutation Conjugation and Order
In summary, the conversation discusses proving the non-existence of a permutation that satisfies (a-inverse)*(1,2)*(a) = (3,4)(1,5). It suggests using cycle types and invariance under conjugation, or considering the mapping of elements 1 and 5 under the permutation a.
fk378
367
Prove that there is no such permutation a such that
Does it have something to do with the order of (1,2)? I know the order is 2, so if we square (a-inverse)*(1,2)*(a), then we get the identity...how else can I think about it?
Do you know anything about cycle types? In particular, can you prove that they are invariant under conjugation?
If not, notice that 1->5 on the RHS. Convince yourself that (1,2) must send a(1) to a(5). Do the same for 3.
By a(1) and a(5) do you mean the numbers 1 and 5 in whatever the permutation a is?
What is permutation conjugation?
Permutation conjugation is a mathematical operation where the elements of a permutation are rearranged based on a given rule or pattern.
What is the difference between permutation and permutation conjugation?
Permutation is the reordering of a set of elements, while permutation conjugation is the rearrangement of a permutation based on a specific rule or pattern.
What are the different types of permutation conjugation?
There are two main types of permutation conjugation: cyclic permutation conjugation, where the elements are rearranged in a cyclical pattern, and non-cyclic permutation conjugation, where the elements are rearranged in a non-cyclical pattern.
How is permutation conjugation used in mathematics?
Permutation conjugation is used in various fields of mathematics, including group theory, abstract algebra, and combinatorics. It is also used in cryptography and coding theory to create secure codes.
Can permutation conjugation be applied to any set of elements?
Yes, permutation conjugation can be applied to any set of elements as long as they can be rearranged based on a given rule or pattern.
  • Math Proof Training and Practice
