Perpetual integration
  • Thread starter lemon
lemon
200
1. somebody please help me:
I have to integrate the following:
https://www.physicsforums.com/attachment.php?attachmentid=24485&d=1268939055
as you can see I have an answer - this is such a long problem - it's like an integration of an integration of an...
and the final answer gives a math error in the calculator.
I also get a value out of calculator of -7.169337845
thank for any advice
Answers and Replies
VeeEight
614
I am unsure of what the problem is. What are you trying to integrate? I see "I have to integrate the following:" and nothing following.
lemon
200
you cant see the problem on the image?
gabbagabbahey
No. I used the quote button on your original post and it looks like you are trying to post an image just by putting image tags around an http address for an attachment. I don't think that works even if the http address links to an image in jpeg form. To make things worse, it looks like the attachment http address is invalid.
Try uploading your image to a free image hosting site like imageshack.us and then just posting the forum hotlink url that they give you.
Either that or take the time to type out your problem statement and the key lines in your attempt like everybody else does.
lemon
200
I'll ask you to leave your sarcasm for another arena please.
This was typed out properly in mathType.
gabbagabbahey
I wasn't being sarcastic. This forum supports [itex]\LaTeX[/itex] and it is often quicker for you to type it out here than to type it up in a separate document and then post it as an attachment or upload it to an image hosting site.
lemon
200
sorry - it's been a long week. I will look into it:bugeye:
lemon
200
[itex]
\begin{array}{l}
\int_0^3 {2x^3 e^{ - x} dx} \\
= \frac{{13\left( { - 12 - e^3 } \right)}}{{e^3 }} \\
\end{array}
[/itex]
lemon
200
tricky
gabbagabbahey
there are two different types of tags you can use...the ones I used were "itex" which is short for inline LaTeX and is only good for short expression that you want to appear inline with the rest of your text. For larger expressions, just use "tex" tags.
[tex]\begin{aligned}\int_0^3 2x^3 e^{ - x} dx & = \left.-6x^2e^{-x}\right|_0^3 +\int_0^3 6x^2 e^{ - x} dx\\ & = \left.-6x^2e^{-x}\right|_0^3+ \left.12xe^{-x}\right|_0^3 + \int_0^3 12x e^{ - x} dx \\ & = \frac{{13\left( { - 12 - e^3 } \right)}}{e^3}\end{aligned}[/tex]
Were you trying to post something like this? You can click on the image to see the code that generated it (or quote my post to see it without all kinds of extra spaces and line-breaks).
lemon
200
thank you gabbagabbahey
I will take a look at it over the weekend.
Is that the correct finished solution you posted above?
gabbagabbahey
No.
Is that the problem you are trying to calculate?
lemon
200
yes
it is the problem
but it went on and on and...
gabbagabbahey
It shouldn't go too long. Just use integration by parts (IBP) 3 times.
Why not show me your first iteration of IBP...
lemon
200
i have attached a .pdf file of my written workings
hope you can read my scribbles
  • int.1018.pdf
lemon
200
it is all part of this attached .pdf file.
I have succeeded to complete part one of the question.
  • questionimage019.pdf
8,207
Changed your [ itex] tags, and got rid or your array stuff.
[tex] \int_0^3 {2x^3 e^{ - x} dx} \\
= \frac{{13\left( { - 12 - e^3 } \right)}}{{e^3 }} [/tex]
gabbagabbahey
It looks like you've done all the individual iterations of IPB properly (although you've neglected to write the integration limits in at each step).
You're problem is with the arithmetic after you substitute in your limits of integration:
[tex]\begin{aligned}\int_0^3 2x^3 e^{ - x} dx & = \left.-2x^3e^{-x}\right|_0^3- \left.6x^2e^{-x}\right|_0^3 - \left.12xe^{-x}\right|_0^3-\left.12e^{-x}\right|_0^3 \\ & = \left.-2e^{-x}\left(x^3+3x^2+6x+6\right)\right|_0^3 \\ & = -2e^{-3}\left(27+27+18+6\right)+2e^{0}\left(0+0+0+6\right) \\ & \neq \frac{{13\left( { - 12 - e^3 } \right)}}{e^3}\end{aligned}[/tex]
gabbagabbahey
IPB - integration py Barts?:smile:
My calculus teacher's name was Ms. Edna Krabappel o:)
lemon
200
so the answer is 4.233217335?
gabbagabbahey
That's the approximate numerical value of the answer, yes. The exact answer involves [itex]e^3[/itex].
lemon
200
cool.. Thank you
Suggested for: Perpetual integration
35K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
