Is a perpetual motion machine possible?
In summary, a perpetual motion machine, which is a hypothetical device that can operate indefinitely without any external energy source, is not possible due to the laws of thermodynamics. These laws state that energy cannot be created or destroyed, only transformed, and that every energy transfer results in some energy loss. Therefore, a perpetual motion machine would violate these laws and is not scientifically feasible. While there have been many attempts to create such a machine, none have been successful.
I guess I'm not all too clear with that drawing versus your statements.
In other words, what stops the system from reaching a static equilibrium?
Yeah, if the energy comes from the magnetic fields, and the magnetic fields deminish(sic), then the energy diminishes, too. Hence, you do not have a perpetual motion machine.
Isn't that what I said?
Tom: Yeah, if the energy comes from the magnetic fields, and the magnetic fields deminish(sic), then the energy diminishes, too. Hence, you do not have a perpetual motion machine.
Trilairian: Isn't that what I said?
No, what you said is consistent with everything in my quote that comes before the word "Hence". You of course did not explicitly conclude that this is not the design of a bona fide perpetual motion machine. All you said about that is the title of the thread, which led me to assume that you believe that this is a design of such a machine.
I didn't find Trilairian's statement ambiguous.
By stating where the energy ultimately comes from, he is clearly disqualilfying it as a PMM.
Neither did I. He clearly stated that the fields are being diminished.
By stating where the energy ultimately comes from, he is clearly stating where the energy ultimately comes from. :biggrin: Nothing more.
It's not that what he wrote is unclear, it's that he didn't complete the thought. And it's not at all obvious from what was written that the correct "if...then" inference was meant. Indeed, the thread title seemed to indicate the opposite.
The left N repels the N-charged shuttle, then the right N repels the N-charged shuttle. Yes, it would merely stop at equilibrium.
If it were possible to build such a device.
Which it isn't.
The device requires a monopole - if such a thnig were actually found or manufactured, we would be well on our way to a new technological revolution.
Which it isn't.
Would it work (seek equilibrium, that is) if that were the end view of 3 bar magnets riding in horizontal slots?
What you're describing could be made fairly easily. 3 bar magnets with all N ends and all S ends together. If the end magnets were fixed and the middle magnet could slide, the middle magnet would behave exactly like a spring if pulled to one side and released. It would eventually come to rest more or less equidistant from the end magnets.
Thanks, Zoob. That's what I thought, but I wasn't sure if some other effect might interfere when there were 3 magnets instead of just 2.
Zoob is zooby is zoobie.
The only Known Perpetual Motion 'Machine' is the Universe itself, going on since time = 0 stopping at time = ∞ or who knows?
:uhh: :uhh: :confused: That's possibly misleading. Technically correct, I guess, since time in our universe began with the same incident as everything else, but there was still a beginning and eventually there'll be some kind of end when entropy has fulfilled it's duties. (I think...:confused: )
But it has NEVER stopped moving, BILLIONS of Years of Motion, all of the atoms, Molecules, masses, moving, all the time, has been that way since the beginning .. .. .. .. .. till the end .. .. .. .. ..
Aye, there's the rub. 'Perpetual' means 'without end'.:approve:
.. .. .. .. And if the end, and the beginning, are the same thing, then it is Peeeeeeeeeerrrrrrrpetual! We will all Need to wait just a Little bit to find that out .. .. .. .. .. .. ..
LD
You've got me a bit confused there, but I wonder if this might be starting to drift into philosophy. Defining the beginning and end of time is probably beyond the scope of this forum.
By the way, why on Earth do you keep leaving that trail of Trix behind you?
Look! is' ****
I haven't defined it, simply noted that they could be the same thing, so the 'perpetual' is beyond the scope of human thought. :bugeye:
As for the trail of trix as you so quaintly put it, it isn't "Trix" it is a Rabbit's footprints 'hopping along' and the other part, is a remnant of my diet! :yuck: :tongue2: :tongue: :blushing: :biggrin:
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
ok this might seem like a very stupid question ,still can anyone relieve me of my ignorance about how to isolate a single magnetic pole ?
does anyone know about the vapour -wheel perpetual motion machine ?
The only way I could ever think of would be to make a hollow sphere in parts. Magnetize it so the outside was all one pole, and the inside the other, then bond the parts together strongly.
I might know what you're talking about. This is a hollow wheel with hollow spokes on a hollow cylindrical shaft. Inside is some volatile liquid, and a hanging, weighted port opening and closing mechanism. As the wheel turns, the liquid flows into a spoke, over balancing that side of the wheel putting torque on it. However, since it's volatile it vaporizes before it stops the wheel at BDC. The vapor is lead back into the cylindrical shaft where it condenses back into a liquid. It keeps running so long as the shaft temperature is kept below the vaporization point of the liquid, which can be done by just keeping it wet. It's not perpetual motion: just a low temperature differential heat engine. If we're talking about the same thing.
Yupp ! Thats Exactly What I Was Talking About .
As far as I know, you can't get a magnetic monopole. Scientists are still searching for one though because if it exists, it would explain the quantization of charge.
russ_watters said:
That's the operating principle behind http://www.mmmetals.com/pages/heat_pipe_heat_sinks/heat_pipe_heat_sink.htm" heat exchangers, btw.
That's cool, russ. I wasnt aware of that system.
The function of the thing Extreme_Machinations mentioned is not heat exchange, though, but to actually produce torque. I ran across it in a very old issue of Popular Mechanics, or Popular Science, maybe 1960's, and actually went to the library and looked up the patent for a detailed explanation of how it worked. It was a really interesting devise, to me, but probably never went anywhere since it hardly produces any power for its size.
I think you could configure your heat pipe to tilt up and down like a seesaw and take the same amount of power off it.
I can't understand anyone looking for a magnetic monopole. Once you see how the dipole is created it seems completely obvious there's no monopole possible.
Magnetic monopoles are predicted by a few theories, including all Grand Unified Theories (GUT theories).
See for instance
http://budoe.bu.edu/~corth/monopole_faq.html
which doesn't appear to be any sort of "official" faq, but is fairly well written IMO.
See for instance
Yes, but we see it says:
How much of my tax dollars are going into this joke?
People often wonder ask what good pure research is doing them. It's often hard to come up with a convincing answer. The bottom line is that all science, even wacky sounding science like looking for magnetic monopoles, can have far reaching affects in the future. Quantum Mechanics doesn't have a lot to do with daily life either, but computers wouldn't work without someone having understood something about it.
When you understand the magnetic field around a current carrying conductor to be, sort of, pointing around in a circle at right angles to the current flow, it seems absurd to suppose that this force could be "halved" somehow, any more than you could "halve" anything that is going in circles. Just imagine half of this guy::rofl:
The only real perpetual motion is the motions these folk perpetually go through to try and prove that there is perpetual motion.
1. What is a perpetual motion machine?
A perpetual motion machine is a hypothetical device that can continue to operate indefinitely without any external energy source. It would essentially create energy out of nothing, which goes against the laws of thermodynamics.
2. Why is a perpetual motion machine considered impossible?
The first and second laws of thermodynamics state that energy cannot be created or destroyed, only converted from one form to another. This means that a perpetual motion machine would violate these laws by creating energy out of nothing.
3. Have any perpetual motion machines been successfully created?
No, despite many attempts throughout history, no perpetual motion machine has ever been proven to work. Many have been debunked as hoaxes or have been found to rely on hidden energy sources.
4. Are there any potential benefits to creating a perpetual motion machine?
The idea of a perpetual motion machine has intrigued scientists and inventors for centuries, and some believe that if it were possible, it could provide an endless source of energy. However, the laws of thermodynamics suggest that this is not feasible.
5. How does the concept of perpetual motion relate to other scientific principles?
The concept of perpetual motion is closely tied to the laws of thermodynamics, which govern the behavior of energy in all systems. It also relates to the concept of conservation of energy, which states that energy cannot be created or destroyed. Additionally, the pursuit of a perpetual motion machine has led to advances in other areas of science and technology.
  • General Discussion
